Old 09-09-2015, 08:12 PM   #1
thereelfish
My Ride: 2002 325ci
I have tried almost everything HELP! CAR WILL NOT START
Ok I will try to be as clear and concise with my situation so that everyone who reads this can have a crystal clear understanding. I have a 2002 325Ci that I bought clean as a whistle but without an engine. I then ordered an M54 motor and had it swapped out. Everything was running fine until about 4 weeks in when I got a no crank no start situation. Upon inspection it turns out the party whom I purchased the car from installed the wrong battery before selling me the car. So I replaced the battery, still nothing. I then replaced the ignition switch due to symptoms common with a bad switch (radio cutting out, headlights not working, tail lamps not working, sunroof...etc) still no dice. I then conclude that my starter is the culprit. Have the starter replaced and WA LA!!!! it runs. 3 days after my starter is replaced I get a long crank situation. Let the car sit, try again and up it fires. The following day I encounter the same situation in town, let it sit try and crank but that is all it does it crank. After repeated tries I cave and call the tow truck. At my indy shop I have the fuel rail checked for fuel pressure, and there was none. So we order in a new fuel pump. I personally replace the pump and crankshaft sensor, and it still just cranks. This is becoming extremely annoying especially since I have had the car for only 2 months. Could my fuel filter be clogged? After the pump change we get fuel rail pressure on the prime, but after it slowly loses pressure to the rail. Im out of ideas. Has anyone ever been in this situation? What else could this be besides the fuel system?
thereelfish is offline   Reply With Quote
Old 09-09-2015, 09:06 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Try a few things.
First pick up a can of starting fluid and see what happens when you give a good 2 second burst of starting fluid into the MAF opening. If the problem is fuel related, the engine will crank, start, then die.
If you get crank only, not even a kicking or any hint of running, then the problem is not likely fuel related.
The next likely problem is the engine being flooded. Trust me, it happens all the time even in warm weather. If you get no life out of the Starting Fluid test, hold the throttle to the floor and try to crank the engine for no longer than 30 seconds at a time. Wait a few minutes between cranking to allow the starter to cool. Try this 3 times, if the engine is flooded, you should be able to get it started after 3 attempts.
Watch the tach while you are cranking, it should register a steady 100-150 RPM.
Also check all fuses, both in the glove box and DME box.
Report back results.
Old 09-09-2015, 09:09 PM   #3
illuminated
My Ride: '99 S2 M3 | 5MT
jfoj strikes again. thereelfish, please heed his advice. In this scenario you are likely feeling like your car is a pandoras box of problems that could be related to your symptoms. Given proper use of diagnostics (as jfoj has detailed); it is only a matter of time before you uncover the exact cause of your no-start. You WILL fix this issue, provided you have the patience to correctly diagnose.
F3RN
Need anything 3D printed? I'm your guy. Send me a pm
illuminated is offline   Reply With Quote
Old 09-09-2015, 09:24 PM   #4
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
do you get fuel pressure every time the pump primes? have you replaced the fuel filter? it absolutely sounds like a fuel problem if you're getting no pressure when the car is cranking.
Old 09-10-2015, 12:04 AM   #5
Archbid
My Ride: 2003 330cic
If you want to be clear and concise, please, please, please use the return key when you are typing. This paragraph is unreadable.
Archbid is offline   Reply With Quote
Old 09-10-2015, 12:39 AM   #6
Islander72
My Ride: 2001 BMW 330ci
Have u hooked up the car to a GT1 or similar scanner?
Islander72 is offline   Reply With Quote
Old 09-10-2015, 10:12 AM   #7
thereelfish
My Ride: 2002 325ci
Ok guys freak out over. Turns out that it was just the DME that needed to be re-synced, but the fuel pump was bad also
Old 09-23-2015, 07:22 AM   #8
franz
My Ride: 03 330i
How do you re-sync the DME?
franz is offline   Reply With Quote
Old 09-23-2015, 10:17 AM   #9
thereelfish
My Ride: 2002 325ci
I had my buddy re align it with a snap on scan tool
Old 09-23-2015, 10:20 AM   #10
franz
My Ride: 03 330i
Is this a red herring?
Old 09-23-2015, 10:38 AM   #11
thereelfish
My Ride: 2002 325ci
I guess idk what model it is, its wireless and costs like 12k
Old 09-23-2015, 11:18 AM   #12
franz
My Ride: 03 330i
haha no I meant is the whole "realignment" thing a red herring.
A Red Herring is a fallacy in which an irrelevant topic is presented in order to divert attention from the original issue.
Old 09-23-2015, 11:26 AM   #13
thereelfish
My Ride: 2002 325ci
oh sorry I read that as "is it a red herring" but this is the whole issue. everything with my starting system is new besides the fuel filter. Are you knowledgeable with DME/EWS problems? My EWS is also new
Old 09-23-2015, 02:17 PM   #14
djdonis
My Ride: e39 540i M, 330i 6sp
Just another useless thread.
Diagnosis - BMW...
djdonis is offline   Reply With Quote
Old 09-23-2015, 02:38 PM   #15
franz
My Ride: 03 330i
Has the fuel filter been replaced yet?
Old 09-23-2015, 04:19 PM   #16
austine46
My Ride: m54b25
OP isnt listening i dont believe. Jfog will say this himself, every e46 needs a new fuel pump and filter by now. Or something like that..
everyone's a critic
FS: coupe facelift xenons, stock headers no cats, stock sport suspension for coupe, oil separator, non m coupe lip
austine46 is offline   Reply With Quote
no start
