Old 09-11-2015, 11:31 PM   #1
Nolans328ci
My Ride: 2000 BMW 328ci
Exhaust size
I'm about to buy an aftermarket performance muffler. I have a 2000 328ci. Just curious if anyone could tell me the correct inlet size to buy. Thanks
Nolans328ci is offline   Reply With Quote
Old 09-12-2015, 03:46 PM   #2
6th Element
My Ride: 2001 BMW 330i
Inlet should be 2 inches
"Never Mind What Haters Say, Ignore 'Em Till They Fade Away"
Instagram: TonyE46
6th Element is offline   Reply With Quote
Old 09-13-2015, 04:27 PM   #3
e46onmeth
Are you sure that's correct I just cut my muffler off and welded a 2.5" pipe on my 330ci the inlet was 2.5" is it different for the 328?
e46onmeth is offline   Reply With Quote
Old 09-14-2015, 02:55 PM   #4
Nolans328ci
Yeah I'd think the 330 is the same as the 328 since it's almost the same size engine. Also most of the after market mufflers say 2.5 or 2.25 inch inlet
Old 09-14-2015, 07:26 PM   #5
Nolans328ci
Okay I just went and measured it its 2.25
Old 09-14-2015, 07:48 PM   #6
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Before you purchase, post up links to possible mufflers.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 01-30-2016, 12:32 AM   #7
swordsman11868
My Ride: 2003 325i
Any opinions?
https://jet.com/product/detail/23d90...PjsRoCjQrw_wcB
Flamesuit on
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
Old 01-30-2016, 11:45 AM   #8
Rob43
Rob43's Avatar
Originally Posted by swordsman11868 View Post
That's a nice quality muffler, it of course will require welding to get it installed properly.
Rob43
Old 01-30-2016, 03:59 PM   #9
swordsman11868
My Ride: 2003 325i
Rob43
Thanks Rob! I plan to have it installed anyway.
I appreciate the confirmation. The cheap mufflers don't give a lot of information regarding fitment.
328ci, e46, exhaust, muffler
