Old 09-16-2015, 03:45 PM   #1
omarda325i
My Ride: 2002 325i
fuel pump or fuel filter??!!?
325i 2002 159k miles
i;ve got my problem down to 2 things either fuel pump or filter
my car has hesitation on acceleration.
when i floor it it has hard time gaining speed. from 0-60 hiccups and some times get stuck on 40mph. but when i put the throttle 50% it seems to do decent but still not all the power is their. rarely when i floor do does the car clime up speed decently not even smooth.-
it idles okay.
yesterday after driving 20+ miles i was at red light and when it got to green
the car started moving really slowing it would not get over 20mph and it struggles and jerked. until it gained some speed and then started going.
some times when i rev the car while idling it gets stuck on 3000-4000rpm and doesnt clim anymore until i release and push again, but most of the time while idling it revs okay.
FUEL TRIMS N INFO FROM OBD2
Fuel trims- from bank 1 and 2 my long fuel trims are at 0.0 and 0.78
and nothing happens when i rev
my short fuel trim is at 27 and gets better as i rev. from both banks
also the engine load shows to be at around 12 and 20 when parked.
can anybody help me pls
omarda325i is offline   Reply With Quote
Old 09-16-2015, 03:56 PM   #2
franz
My Ride: 03 330i
You should probably do both.
franz is offline   Reply With Quote
Old 09-16-2015, 04:06 PM   #3
DEADF15H
My Ride: 2001 325i Auto
Here is the best thread on fuel pumps/filters. http://forum.e46fanatics.com/showthr...ight=fuel+pump
You can do the fuel pump (the biggest culprit), the filter and the relay for under $200, it's a simple DIY, even for a novice (I know this, because I am one).
The pump only takes about 15 minutes of actual work, and is a known weak link on our 10 year + old cars. Find the DIY.
The pump its located under the back seat, the filter under the car on the left side, the relay is behind the glove box and the trickiest part of the R&R. These parts are highly recommended as a preventative maintenance item, because sooner or later, they ARE going to fail.
DEADF15H is offline   Reply With Quote
Old 09-16-2015, 05:20 PM   #4
omarda325i
My Ride: 2002 325i
can it still be fuel pump if the car runes fines when low on gas and the gas meter works normal too when low on gas ??!?!?!?!?
Old 09-16-2015, 05:24 PM   #5
omarda325i
My Ride: 2002 325i
maybe my car is on original fuel filter since 2002.?
i get code p1085-low fuel pressure.
i cant do the fuel filter and fuel pump both at once it'le be way too much money then i can pay out.
Old 09-16-2015, 05:26 PM   #6
jfoj
My Ride: 330CiC, M5, X5, E93
I would put a fuel pump in before the filter.
Siemens/VDO fuel pump/fuel sender assembly unit delivered is around $135 from www.bmaparts.com using the discount code SPECE30.
You need 1 small worm drive hose clamp and about 30 minutes, it is easier to replace the fuel pump than change a tire IMHO.
Old 09-16-2015, 05:43 PM   #7
omarda325i
My Ride: 2002 325i
when i start my car i hear the fuel pump and its kinda loud is that normal?
Old 09-16-2015, 06:08 PM   #8
cvx5832
My Ride: 325Ci, 325Cic, C300
it idles okay.
I had the same symptoms on my Coupe when it had 89k. Fuel pump solved it although I would follow others' suggestions to replace the filter too.
cvx5832 is offline   Reply With Quote
Old 09-16-2015, 06:09 PM   #9
omarda325i
My Ride: 2002 325i
did it accelerating horribly
Old 09-16-2015, 07:41 PM   #10
omarda325i
My Ride: 2002 325i
i just went on a 6 miles trip to the store and came back.
the car didn't have check engine light but it did pop 3 codes. lean codes p0174 and p0171, also 1351. but no p1085-low fuel pressure. it despaired
can these be fuel pump triggering these codes. because i think my car is not having a vacuum leak.
Old 09-16-2015, 08:06 PM   #11
franz
My Ride: 03 330i
The short answer is yes, lean is equivalent to having enough air and not enough gas, or enough gas and too much air.
Old 09-16-2015, 08:43 PM   #12
omarda325i
My Ride: 2002 325i
yes it must be the fuel pump because right now my car's gas light is on and i takes several times to turn on my car and dies on me while trying to reverse out my house
Old 09-18-2015, 08:22 AM   #13
omarda325i
My Ride: 2002 325i
this morning my car cranks and doesnt start. am thinking its fuel pump. so put in a order on ebay for $44 e46 325i pump with 10 year warranty
http://www.ebay.com/itm/130906114373...%3AMEBIDX%3AIT
Old 09-18-2015, 08:51 AM   #14
jfoj
Somehow I doubt the pump will outlast the 10 year warranty because many of the OE BMW pumps do not even last 10 years.
But let us know how the fit and performance of the pump works out.
I rarely cut corners too hard when the part failure has a high degree of leaving me stranded.
Old 09-18-2015, 10:54 AM   #15
DEADF15H
Scary, they don't even list who the manufacturer is. Hoping you have years of service, but I'm skeptical. Good luck.
Old 09-18-2015, 11:00 AM   #16
omarda325i
My Ride: 2002 325i
hahah, scary ik =/ as long as i get my acceleration and hesitation fixed and couple years use out of the pump i think it'l be justified
Old 09-18-2015, 09:55 PM   #17
omarda325i
My Ride: 2002 325i
do my fuel trims indiacte i have a air leak?
Old 09-18-2015, 10:25 PM   #18
wildirish317
My Ride: 2004 325Ci vert
Curious as to why. I replaced both at the same time. No indication of fuel pump failure, but highly fluctuating O2 short and long term fuel trims.
I replaced the fuel pump bc it's prone to failure. The fuel filter was original, 140+k miles, so it was due.
I've seen better fuel trims, and no codes thrown since. I attribute it more to the filter than the pump.
My opinion is that the filter will cause drivability problems before the pump, as long as the filter has not been changed in the past 60k miles.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 09-19-2015, 12:02 AM   #19
Chris951
Your fuel trims at idle shouldn't vary much more than +/- 5%. My car sits normally around +/- .75-2.5% at idle. And high positive trims like you are showing mean the car is running very lean and its adding fuel to compensate. This could indicate a vacuum leak or a low fuel pressure problem.
Chris951 is offline   Reply With Quote
Old 09-19-2015, 12:13 AM   #20
Licked
My Ride: 330Ci Vert
hows your fuel level when driving ? is it eating up gas????
Licked is offline   Reply With Quote
0-60 slow, fuel pump, slow accerlation
