Old 09-24-2015, 12:42 AM   #1
gabe05
My Ride: 2001 320i
Unhappy Ignition problem... Have to jam key in to start..
Hey guys.
I'm writing this because I have a intermittent no-start problem and I've done everything I can to try and fix it, but I can't find out what's wrong. Everything is fine but to start my car, I need to jam the key in a couple of times before turning it. If I don't, the car doesn't turn over or anything, but all electronics are on. As soon as I jam it, it works.
The obvious guess was a new ignition switch, so I did that but the exact same problem persisted. I have no clue what the problem is and I need help.
tl;dr : My car does not start unless I jam the key in. I just switched the ignition switch and it still doesnt work.
gabe05 is offline   Reply With Quote
Old 09-24-2015, 02:19 AM   #2
scottjoh
My Ride: '99 323i & '02 540i
You need a new key or need this one repaired. The EWS section in the key has developed an intermittent problem. About every 20th key I get in for repair is like that. If you had diagnostic program like PA Soft you could watch the live data from the EWS module and see that it's not reading the key reliably. Simple problem to troubleshoot really, but, without it your just grasping at straws.
scottjoh is offline   Reply With Quote
Old 09-24-2015, 06:33 AM   #3
franz
My Ride: 03 330i
Originally Posted by gabe05 View Post
Hey guys.
I guess it wasn't that obvious, was it.
franz is offline   Reply With Quote
e46, ignition switch, no start
