Old 12-22-2015, 04:17 PM   #1
S.A. Singer
My Ride: 330xi
Throttle Sensor - EML - P0221
So I've been having the christmas tree light up (the one where the ornaments are: DSC, ABS, BRAKE, EML) since I bought the car, but it's never been often enough for me to do anything about it. The lights would come on, sometimes with a P0221 error code, I would restart the car and keep driving. Well anyways, I was driving the other day and when I approached a stop sign I took the car out of gear and the tach needle started jumping sporadically all over the 500-2000 RPM range (NOT the limp home function!). This morning (cold engine) the lights came on along with the limp home function, and a P0221 code. I've looked around online to see what people were doing about it. Should I go straight to buying a new TPS? Has anyone else had this particular issue?
S.A. Singer is offline   Reply With Quote
Old 12-22-2015, 11:58 PM   #2
daniel_f.
My Ride: 330iC
There is no TPS you could buy or change, if its the throttle giving errors, you need to change the whole throttle!
Old 12-23-2015, 07:43 PM   #3
S.A. Singer
My Ride: 330xi
What do you mean by that? Or more to the point - what do you think I should I buy to fix it?
Old 12-23-2015, 08:23 PM   #4
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Your car is drive-by-wire and the accelerator position sensor is built into the accelerator pedal assembly.
http://www.realoem.com/bmw/enUS/show...diagId=35_0282
You can view the accelerator pedal position and the throttle opening angle using INPA. This should give some insight as to whether either of these is the problem.
///Mmmmmm...
eml, limp, p0221, sensor, throttle
