Old 01-11-2016, 09:57 AM   #21
jfoj
My Ride: 330CiC, M5, X5, E93
Cancel the Peake Reader order, a total overpriced boat anchor.
Get OBDFusion and the correct interface for under $30.
For the life of me, I have no idea why people keep buying the Peake Reader.
Read this thread, but keep in mind it is about 3 years old, OBDFusion is what you want.
http://forum.e46fanatics.com/showthr...&highlight=obd
Old 01-11-2016, 10:28 AM   #22
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Originally Posted by kevman2 View Post
Just ordered a Peake scanner to check codes, and clear the sevice engine soon light. I'll let you know. I checked to make sure i installed correctly, and make sure the gasket was seated properly. All good...
Return that Peake pile of junk and get a much better tool, wireless OBDII interface and OBD Fusion app, for a lot less money. See one of jfoj's posts for details.
Edit: James beat me to it!
///Mmmmmm...
325ci 330ci, e46, fuel pump, fuel pump relay
