Sponsored by BimmerWorld
Old 01-13-2016, 03:38 PM   #21
CREAO
My Ride: 2001 325i
So finally I have finished my DIY project. I somehow have resolved the mysterious ticking noise by tighening the upper strut hat making sure all bolts and connections were tight as well as studs, as well as bending the rotor dust covers as far as I could without damaging them to wear it looked normal. But hey for 17 years old what can you expect?
CREAO is offline   Reply With Quote
Old 01-13-2016, 10:15 PM   #22
06330CIe46
My Ride: 2006 330CI
I have the same FK's on mine and I'm having the exact same problem. However, this problem just started and the coilovers have been on for about 8 months now. I thought it might have been a control arm bushing.
06330CIe46 is offline   Reply With Quote
Old 01-13-2016, 10:51 PM   #23
CREAO
My Ride: 2001 325i
Could be the whole 9 yards... I had the ticking and this is what I did :
-Rebent rotor shields, even if they weren't touching
-tightened upper strut mounts (front) by using a vice grip with cloth around the strut to protect it from scratching, then proceeding to use an impact wrench on them
-checked end links
-Checked assembly of coils,
-added 12.5mm hub centric spacers by ECS tuning
-realized the right front passenger side assembly's locking ring wasn't locked into place.
After all that was said and done, the clicking stopped (knock on wood).
coilovers, e46, front, issues, ticking
