Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Old 03-15-2016, 07:45 PM   #1
YoitsTmac
My Ride: 328Ci
Painting pre-facelift coupe bumper trim
Hey fanatics! I've searched around quite a bunch and I'm surprised that I can't find anyone who has done this. On the pre-facelift coupes, the fog lights trim, the grill in between the fog lights (front bumper cover trim), and the thin sheet that goes all the way across (grill cover). On non sport models, the fog light trim and grill come in black, and the grill cover comes in your exterior paint color. However, on some models (sport package?) this trim is grey, or as I've seen it called "titan."
I have no experience in paint or anything whatsoever. Is it possible to just spray paint these and get the OEM look? Should I plasti dip them? And for the grill cover that is my exterior color color, do I need to sand the clear coat off for a paint to stick? and is there a type of paint or color or something that I should get? I'm really shocked there's nothing on this, but usually people are trying to pain their interior pieces. I figured this is a "nothing can go wrong" DIY. I have a photo of some random persons E46 who has the bumper OEM with the trim colored. I just want some contrast in my grill!
Name:	sport bumper.jpg
YoitsTmac is offline   Reply With Quote
Old 03-15-2016, 08:14 PM   #2
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
I think those were the same color across all Ci cars. Some people may have just painted them black for aesthetics I assume. To remove that piece, I would imagine you have to take the front bumper off. I know that is how it works on sedans as I've done it.
For the OEM look, I would just leave it as it is
>IN SEARCH OF GRAY SEDAN SPORT SEATS<
lllRazorlll is offline   Reply With Quote
Old 03-15-2016, 08:21 PM   #3
YoitsTmac
My Ride: 328Ci
I think it came from the factory black. The part numbers below are for the fog trim, but are different for "titan," and "black," so there was some package or trim that made these cars specced with the trim in silver. This especially makes sense since the grill cover is my exterior color, where it is silver on others.
51118204357 (black)
51117016515 ("titan")
My E46 isn't sporty looking. It has 16" rims, is steel blue, and has chrome trim. The inside is dove with wood trim. I feel it has a very "calm" look to it, and I think these would help continue that look. Even if it was sporty (glossy black window trim, bigger rims), I like these accents. It gives some contrast to an otherwise all black grille. It's down low so typically isn't seen. I want to give it some pop
Old 03-15-2016, 09:20 PM   #4
orb
orb's Avatar
My Ride: 325Ci
You have a blue factory interior? Lucky, that's pretty rare.
orb is offline   Reply With Quote
Old 03-16-2016, 12:36 AM   #5
YoitsTmac
My Ride: 328Ci
sorry I meant dove. It just always appears blue to me.
Old 03-16-2016, 01:47 AM   #6
glhx
My Ride: 2002 330ci
I have posted a lot about painting in my sig
Gray scotch Brite pad
Scuff clear till dull
Clean
Paint
Clear
Sand
Buff
glhx is offline   Reply With Quote
Old 03-16-2016, 10:53 AM   #7
williamp525
My Ride: 330I Sports Touring
I have just done my interior trim and grills and mesh on my car. I know its the sport model touring but same principles
ID:	626863   Click image for larger version
williamp525 is offline   Reply With Quote
Old 03-16-2016, 10:55 AM   #8
williamp525
It was chrome and wood also
Old 03-16-2016, 08:36 PM   #9
lllRazorlll
Modded ///Member
My Ride: '00 328i
Figured it out. The 325Ci had black trim running along in the bumper and the 330Ci had gray/silver trim. Gave it more of a premium look. 323 and 328Ci models both had black trim.
Edit: I see your ride is a 328Ci. I'm sure there was a specific reason as to why there were two trim colors. Sport package vs. non sport? Idk. I do know that the grille in the "mouth" of the bumper for the 323/325i and 328/330i were different
Old 03-17-2016, 12:44 AM   #10
YoitsTmac
My Ride: 328Ci
Clean
Paint
Clear
Sand
Buff
I've done a bit of research and think this is the right thing to do. I found your post in my original research, but found most of it about painting metal. Few questions though. The scotch brite pad would be for removing the original paint, correct? And what grit do you recommend for "polishing" down new coats? Only familiar with sand paper because I've looked into repairing some of my babies many scratches.
Thanks for this. I just thought that the outside would need something extra care since it would be taking far more abuse than the inside. I now see that this is not the case
Figured it out. The 325Ci had black trim running along in the bumper and the 330Ci had gray/silver trim. Gave it more of a premium look. 323 and 328Ci models both had black trim. So spray paint should be good?
I did some more googling and I think you're right, that only the 330Ci's got this. I have the black trim, so I'm going for the more premium look!
EDIT: good place to get spray paint? good brand?
EDIT 2: Is it necessary to sand the pieces that are black? Can't I just paint over them?
Old 03-17-2016, 08:49 AM   #11
lllRazorlll
Modded ///Member
My Ride: '00 328i
Just go to Home Depot and find a paint that adheres well to plastic/exterior use.
Old 03-17-2016, 09:15 AM   #12
bugsyhoff
My Ride: 325xi
Remember painting is all about prep work. If you want it to look good make sure it is sanded down well before hand. I'm excited to see how this turns out.!
bugsyhoff is offline   Reply With Quote
Old 03-17-2016, 10:12 AM   #13
evanr614
My Ride: used 2 have 2 pedals
if it were me i'd leave it alone unless you plan on painting your headlight trim also. it's not easy to make homemade paint jobs last. not saying it can't be done.
that trim is also kind've a bitch to get off too.
fwiw my 328Ci sport package came with the black bumper trim and headlight trim.
Atlantis Blue 328Ci Project Thread
http://forum.e46fanatics.com/showthr...523&highlight=
evanr614 is offline   Reply With Quote
Old 03-17-2016, 10:50 AM   #14
lllRazorlll
Modded ///Member
My Ride: '00 328i
Yeah, I think 330Ci cars had silver trim. I know that applies to the sedan starting with the 2001 model year. Maybe the previous owner on your car changed the grille/bumper because of an accident?
Old 03-17-2016, 12:20 PM   #15
YoitsTmac
My Ride: 328Ci
I'll post pictures then! This is a job not high on my priorities, since it's all aesthetic. What grit would you say I should use? I'll go to home depot once someone recommends me one (or two)
I really want to give it a shot. If I break it, it's not like it'd be very noticeable. I've also seen videos (would have to dig them up) on how to remove the trim without removing the bumper. If I had to remove the bumper, I wouldn't attempt this.
And so confirmed only on 330Ci?
I have a 328Ci. And I believe that the sedan didn't have this style bumper
Old 03-17-2016, 01:33 PM   #16
DEADF15H
My Ride: 2001 325i Auto
automotivetouchup.com can mix up BMW paint codes and supply them in rattle cans.
You need to follow the instructions exactly! dont take any short cuts, even if your impatient like me, especially on the cure times, between coats. Watch their videos.
Use a scrotch brite pad, their tack cloth, Prep Solvent, Plastic Parts Adhesion Promoter, Base Coat, and Clear Coat. Whatever paint you use, keep all the prep items in the same brand just to be safe.
I used them for Toyota Highlander side view mirrors that were destroyed by the Florida sun. 3 years in, and they still look fantastic.
It takes 3 times longer to prep the piece than it does to paint it!
DEADF15H is offline   Reply With Quote
Old 03-17-2016, 02:15 PM   #17
YoitsTmac
My Ride: 328Ci
Originally Posted by DEADF15H View Post
automotivetouchup.com can mix up BMW paint codes and supply them in rattle cans...Use their Prep Solvent, Plastic Parts Adhesion Promoter, Base Coat, and Clear Coat. Whatever paint you use, keep all the prep items in the same brand just to be safe... It takes 3 times longer to prep the piece than it does to paint it!
I don't need a specific BMW paint. The trim seems to not even be glossy. See the pictures attached. I can understand the prep solvent and plastic adhesion promotor, but I don't need a clear coat, right? The trim has a mat look to it. Unless anyone with this titanium look trim on their 330Ci can tell me otherwise. I haven't looked at the trim really close
ID:	626935   Click image for larger version
Old 03-17-2016, 06:11 PM   #18
DEADF15H
You're right, you don't. You can use any quality primer, paint, and clearcoat, in whatever color. I couldn't see the car color on my phone, thought it was Titanium Silver and you wanted to match it. I'm getting ready to do my shark fin, which I need to match.
Just scuff with a pad for adhesion. If you scuff through the original primer you may have to use some Plastic Primer. Put on a few coats of base color in whatever color you choose. The clear coat is a protector coat, that area gets bombarded with rock chips, sand, salt, and road debris. Pretty sure you can get it in a matte finish as well, if that's what you want. The beauty of those parts is they don't have a large flat surface, so even if you have a few mistakes you don't want to take the time to sand down, it will be hard to notice.
Old 03-17-2016, 07:33 PM   #19
lllRazorlll
Modded ///Member
My Ride: '00 328i
They didn't have the same bumper but look at the grille in the "mouth" the car "face" makes
323i
325i
328i
330i
Note the 330i. Silver headlight trim + bumper plastics for a more premium appearance
Old 03-17-2016, 08:52 PM   #20
TheRarp
My Ride: 02 - 325Ci
original!
TheRarp is offline   Reply With Quote
front bumper, paint, pre facelift, trim
