Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 03-20-2016, 09:07 AM   #1
ssyoumans
My Ride: '01 330i
Should my rebuilt Vanos look like this?
I replaced the valve cover gasket and did the Besian Vanos repair about 5 years ago at 90k on my 2001 BMW. Today, 5 years later and about 35k miles, got to do the valve cover gasket again. When I took the valve cover off, the cams and the rest of the engine looks great, but the Vanos area looks nasty.
Any thoughts on this? I don't recall it being nasty like this 5 years ago.
Everything else looks great.
ssyoumans is offline   Reply With Quote
Old 03-20-2016, 09:38 AM   #2
Mflara20
My Ride: 04 330i
Ill try to run some engine flush. That should help.
Mflara20 is offline   Reply With Quote
Old 03-20-2016, 09:50 AM   #3
dknightd
My Ride: 2002 330 cic
I'm not an expert on this engine. It looks like cooked on oil to me. Are you changing oil often enough, and using an approved oil? I would not worry about it too much, but would start changing oil more often, and make sure it met ll1 specs. Maybe clean off whatever you can while in there.
dknightd is offline   Reply With Quote
Old 03-20-2016, 09:52 AM   #4
hitbyastick
My Ride: 2002 325i
That happens to these. Just keep changing the oil frequently. The 15k oil change interval is too long. Also the BMW oil isn't all that great, even though it is 'approved'. Try using an oil that has more detergent qualities, like something with an ester basestock. Or just scrub it off and put the cover back on and don't worry. It's nothing to worry about as long as you're changing the oil per usual.
Erryboddy got a plan till they get punched in the mouf - Mike Tyson
hitbyastick is offline   Reply With Quote
Old 03-20-2016, 09:54 AM   #5
ssyoumans
My Ride: '01 330i
I use Castrol Syntec 5w30, changed every 7.5k miles. Everywhere else on the Engine looks minty fresh.
Old 03-20-2016, 09:54 AM   #6
cvx5832
My Ride: 325Ci, 325Cic, C300
What oil are you using? I use M1 0w-40 and I don't get that baked on cake over the vanos.
Here's my coupe when I opened it at 83k. You can see the RTV traces from when I first cracked it open to change the VCG at 46k :
Photobucket
Here's at 112k when I opened it again to change leaky Victor Reinz gaskets :
Untitled
I don't think the stain means anything but it is possible not to have it.
cvx5832 is offline   Reply With Quote
Old 03-20-2016, 10:16 AM   #7
orb
orb's Avatar
My Ride: 325Ci
I've been running either Castrol or M1 0w-40 for the last 40k in 7.5k intervals and mine has the gold varnish too, but no "burned on" oil like that. Try shorter intervals, but anything below 7k is a waste. Synthetic oil doesn't even reach it's peak lubricant quality until around 7k. Tons of reading on the subject on the bobistheoilguy forum.
orb is online now   Reply With Quote
Old 03-20-2016, 10:28 AM   #8
hitbyastick
My Ride: 2002 325i
Almost looks like blowby to me, another reason to use an ester-based oil. Good stuff. Rings & valve seals are probably a little gunked and letting the blowby gases into the upper cylinder area. Ester oil gets rid of this and prevents it from forming anew.
Old 03-20-2016, 10:37 AM   #9
swordsman11868
My Ride: 2003 325i
Mostly Mobil 1, 7-10k OCI, 160k miles:
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
Old 03-20-2016, 10:51 AM   #10
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
That is just oil dried up on the vanos. Oil is not circulated on top of the vanos. It got on top of it and dried out from the heat. A little oil can get by the valve cover and get on the vanos like that.
Nothing to worry about.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is online now   Reply With Quote
Old 03-20-2016, 11:02 AM   #11
dknightd
I'd switch to every 5k miles, or once a year, which ever comes first.
Old 03-20-2016, 11:05 AM   #12
dknightd
I don't know oil. Is the one you are using ll-01 approved?
Old 03-20-2016, 11:20 AM   #13
Dave1027
My Ride: '06 IR zhp coupe
Maybe the CCV is not functioning properly?
Old 03-20-2016, 11:42 AM   #14
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Seems like that could just be an issue with either the vanos gasket and/or not using rtv along the seam when doing vcg.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 03-20-2016, 12:16 PM   #15
WDE46
My Ride: '13 128i, '04 330Ci
+1
Mine looked a bit like this though it was to a lesser extent. This is no issue at all.
No idea why some people have grey color and others get the gold/brown color though, even amongst those who use the same oil.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 03-20-2016, 03:50 PM   #16
evanr614
My Ride: 2000 328Ci
cleannnnnnn
Atlantis Blue 328Ci Project Thread
http://forum.e46fanatics.com/showthr...523&highlight=
evanr614 is offline   Reply With Quote
Old 03-20-2016, 08:24 PM   #17
camrydriver111
My Ride: 05 325i
I would not worry about it. Mine looks the same. It's because the oil does not circulate in that area.
M1 0W40 is a better oil than Syntec 5W30 though.
M1 0W40 is approved to go 15k OCI, Syntec 5W30 is not.
camrydriver111 is offline   Reply With Quote
Old 03-21-2016, 08:37 AM   #18
rsyed07
My Ride: E92 335is, E46 330i
I had very minor caked up oil when I did my VCG couple years ago on the VANOS area. Could be from the previous owner waiting 15k for an oil change who knows. But I've been using BMW 5W-30 and had the gold varnish on it as well. Lets hope there is no caked up oil when I do my VCG again in another 50k miles o so.
rsyed07 is offline   Reply With Quote
e46, vanos
