Old 07-30-2016, 09:10 AM   #21
lingon300k
My Ride: 2005 325xi Automatic
Originally Posted by codyneff View Post
Well now the entire system is replaced and it's no longer overheating but now I have a leak coming from underneath the brand new expansion tank I put in a month ago. I Can't win
Your expansion tank wasn't pressed down properly.
Read this: http://forum.e46fanatics.com/showpos...42&postcount=5
lingon300k is offline   Reply With Quote
Old 07-30-2016, 07:27 PM   #22
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
The ET isn't sitting down properly - I realize it's frustrating - perhaps use some lube on the o-rings on the bottom of the ET to get them to slide down and lock
BMW-North E46 Electric Fan Guide
Download a clean working copy of BMW Standard Tools with Special Tests for e46 :
Single NRG file: Complete BMW Standard Tools Suite You will also need ISO Workshop (free edition - linked) to create the install directory (image) or disk. NRG file: 347,183 Kb
BMW-North is offline   Reply With Quote
Old 08-04-2016, 03:44 AM   #23
codyneff
My Ride: 325i
Sorry it took so long for an update guys but I've been caught up at work and low on funds. Now I've done an entire overhaul with damn near everything oem parts. (Radiator, water pump, expansion tank, cap) however the thermostat I got from oreillys just for times sake and it is STILL overheating after multiple bleeds with ignition on heat on 91 fan speed on low and front raised. At this point I was at my wits end so I decided to have it towed to a European car mechanic. When he called me at about 4 he said he had pressure tested the system and said there was no leaks and that the leak I was seeing was from the system over pressurizing and coming out of the et cap. Has anyone ever heard of this before?
codyneff is offline   Reply With Quote
Old 08-04-2016, 08:06 AM   #24
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Have a compression test done on each cylinder. It could be a blown head gasket, which often pushes cylinder gases into the cooling system causing overpressure and usually overheating.
///Mmmmmm...
Old 08-04-2016, 11:30 AM   #25
gtr_gtti
My Ride: 1999 E46 318
i think i have this problem
gtr_gtti is offline   Reply With Quote
Old 08-04-2016, 11:42 AM   #26
codyneff
My Ride: 325i
Just got a call from my mechanic and he said I have a warped/cracked head. Guess it's time to start looking at my options. It was nice for the month it lasted.
Old 08-04-2016, 09:46 PM   #27
BMW-North
That's too bad. I feel for you. Happened to a friend of one of my kids. Po had tried to hide the leaking head using head gasket stop leak. Eventually the pressure buildup came back and hoses would blow off. One of the things that is a good sign of a suspected snake oil head gasket fix is a lack of heat at idle on a warm engine. The sealer clogs the heater core and little heat enters the cabin unless the rpms get very high. I always test heaters at idle when checking used cars.
Karma will get the guy.
Old 01-14-2017, 02:41 AM   #28
codyneff
My Ride: 325i
Just some extra information for you guys and to hopefully get some insight on what this may possibly be I'm going to give an update on this. After a few months of not being able to work on the car I have been messing with some possibilities the past few days. Turns out the heater core is clogged for some reason so as I worked on getting that unclogged I drove it for a good 40 minutes or so without overheating. And unfortunately it started again. I have figured out the thermostat I replaced was faulty. I'm thinking I may not have gotten all of it out of the heater core so I need some advice for after I replace the heater core. If that does not fix the overheating issue what are some more possibilities of what could be causing my overheating here. The car can idle all day long and will not overheat but as soon as you start driving that's when the overheating starts. There is no loss of power. Is there any sensors or valves that could cause this? I really appreciate the help
Old 01-14-2017, 06:20 AM   #29
BMW-North
Cody - The previous owner likely used Stop Leak - that has jammed the heater core but that isn't causing the overheat. See my earlier post.
Unfortunately there is no fixing this issue by replacing peripheral parts. The head gasket is leaking. Whoever sold the car to you tried to hide the head gasket leak by using a snake oil solution which inadvertently also clogs the heater core. Don't throw any more money at it unless it is for a head gasket or engine replacement.
The use of Stop Leak by the previous owner destroyed your heater core and caused other coolant component issues. The small tubes in a heater core have spiral bars inside to slow down the flow of coolant and transfer more heat to the metal. Stop Leak Sealer clogs this. One of the reasons I always test the heater of a used car at idle is to see if the heater blows hot air. If it doesn't often the core is blocked from a sealer - usually to mask symptoms of a blown or leaking head gasket.
What happens is gases from the cylinders are leaking into the coolant via the blown head gasket and causing the pressure to build in your cooling system - this pressure will blow plastic parts up.
Old 01-14-2017, 09:25 AM   #30
BaliDawg
Put a good used low mileage 330 engine in there. You can find a 75k mile 330 motor for around $1,500 on car-part.com.
///Mmmmmm...
cooling, overheating
