Old 09-22-2016, 08:19 AM   #21
GhostFlame
My Ride: E46 Sedan
Remember that amps are drawn, so having a higher spec battery shouldn't matter so long as it is charged.
I doubt that the separate keys will fix anything, since it looks like your OBD2 port just isn't responding.
You probably already went through this list, but I'd double check through it again:
http://forum.e46fanatics.com/showthread.php?t=1011677
GhostFlame is offline   Reply With Quote
Old 09-22-2016, 08:37 AM   #22
GhostFlame
My Ride: E46 Sedan
I am really hoping to get your car working, its almost bothering me.
Looks like you have a CANBUS issue. Your temperature needle automatically going into the red indicates that there is a communication error between the cluster (IKE) and engine computer (DME). Because you say the dealer tested your DME in another car and it worked, it would indicate that DME is not at fault.
Also take a look at these threads:
http://www.bimmerforums.com/forum/sh...rt-Not-Working
http://www.e46fanatics.com/forum/sho...1014046&page=2
http://autotechdiagnostics.com/?p=213
Old 09-23-2016, 03:35 AM   #23
Tbimpy
My Ride: 2001 320CI
How about this:
Hkw about a faulty EWS?
Is it possible that the EWS resetted and not giving the right codes to the DME..
Or the EWS cutting the fuelline.
Or EWS not reconizing the keys?? Cause of reset? And so it gives faulty / no codes to DME ??
Tbimpy is offline   Reply With Quote
Old 09-23-2016, 07:38 AM   #24
jfoj
My Ride: 330CiC, M5, X5, E93
I think them temperature gauge pegging to high may be a clue, but I have not suggestion on what the problem may be.
If the dealer swapped your DME into another car and it worked, did the temp gauge on the test car peg like in yours?
Old 09-23-2016, 08:24 AM   #25
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Battery needs to be 12.5v or more to be charged enough to crank the engine. When below this, there is not enough to support all systems with full voltage.
When diagnosing, you should list specifics and not general values.
Start from the top:
Battery fully charged
Fuses all intact
Voltage seen at +B terminal in engine compartment
Voltage seen at +B terminal in E-Box (DME location)
Connections to DME is seated properly.
Etc.
Go from there.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 10-12-2016, 08:26 PM   #26
Tbimpy
My Ride: 2001 320CI
Had car taken too the dealer..
Car went to the dealer.. Stood there for 1 and a half week, and they still didnt know.. After i brougth my spare keys .. It still wouldnt start... But the day after they tried and it started?? Although they told me so...
Now im here with my next problem:
P0600 serial communication link
****ing hell yes what a lovely code..
Will it be fixed bt updating / flashing the DME with newest software??
Edit: the car runs.. But with the code...
braindead, e46, no communication, no start
