Old 12-13-2016, 09:53 PM   #1
Nolans328ci
My Ride: 2000 BMW 328ci
Camshaft Position Sensor
I have a 2000 328ci with 160,000 miles and The recent symptoms of my car in the past month are:
-Stuck in fourth gear a few times along with CEL (now use steptronic daily to prevent this)
-stalled out at a traffic light the other day when I let off the brake to start driving
-rough idle and RPMs drop drastically sometimes while rolling slowly
-periodical significant loss of power (no "get up and go")
-check engine light can't decide whether to turn on or off
So I took it to my previously favored shop and they called within the first day saying I needed an entire transmission. $2800. I'm no mechanic, but I thought that was a load of crap since I can still shift the car fine using manual mode (it's an automatic). It returned to normal for a while, but now has the loss of power and even stalled once at a light. The CEL was off but I was still able to get the code reading:
P0340- Powertrain
Camshaft position sensor "A" circuit (bank 1 or single sensor)
When I researched this code, it said getting stuck in a certain gear and stalling or loss of power was a symptom. Has anyone else had similar experiences? Should I just replace the sensor? And if so, would it be the exhaust side or intake side?
Nolans328ci is offline   Reply With Quote
Old 12-13-2016, 10:25 PM   #2
WDE46
My Ride: '13 128i, '04 330Ci
I'd definitely try a new sensor. Replace both if you can afford it. Otherwise, I think that's the intake. Get Siemens VDO (OEM) brand or Genuine BMW ONLY! rmeuropean had a good deal last I checked. They were just labeled OEM. They're Siemens.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 12-13-2016, 10:52 PM   #3
evanr614
My Ride: 2000 328Ci
FCP has "OEM' ones for the right price too
Atlantis Blue 328Ci Project Thread
http://forum.e46fanatics.com/showthr...523&highlight=
evanr614 is offline   Reply With Quote
Old 12-14-2016, 02:08 AM   #4
YoitsTmac
My Ride: 328Ci
Bank A is intake. I've been there, lost power brakes and steering as I faced a right turn downhill with a wall approaching. Wouldn't wish that on anyone
YoitsTmac is offline   Reply With Quote
Old 12-17-2016, 11:46 PM   #5
Nolans328ci
I found a VEMO one for $50. Are these known to fail?
Old 12-18-2016, 10:02 AM   #6
jmo69
My Ride: 03 325xi 98 328is
Buy OEM or Genuine BMW, there is a reason people tell you not to buy aftermarket, they don't work.
Hers His
2003 325xi StahlGrau metalic almost modless, just lots of new parts, wife's DD. 1998 328is lowered, X-brace, Sparco strut brace, HIDs, AEs, almost everything blacked out, my DD.
jmo69 is offline   Reply With Quote
Old 12-18-2016, 10:04 AM   #7
orb
orb's Avatar
My Ride: 325Ci
As WD said the OEM Siemens are cheaper at RMEuropean than Meyle or Vemo elsewhere. They've been redesigned since the car was manufactured so expect them to look slightly different.
orb is offline   Reply With Quote
Old 12-18-2016, 10:08 AM   #8
BKMrSteel
My Ride: 99 328i
Only buy OEM / Genuine BMW camshaft and crankshaft position sensors to avoid problems. I think most people who say this have lived it.
<a href=http://forum.e46fanatics.com/showthread.php?t=1094528 target=_blank>http://forum.e46fanatics.com/showthread.php?t=1094528
</a>
BKMrSteel is offline   Reply With Quote
Old 12-18-2016, 11:06 AM   #9
OnTheFence
My Ride: 2001 330i (and 530i)
Which sensor is the one right up front near the valve cover?
Cam or crank?
OnTheFence is offline   Reply With Quote
Old 12-18-2016, 11:09 AM   #10
jmo69
Cam or crank?
Cam
Hers His
Old 12-18-2016, 02:45 PM   #11
WDE46
Cam or crank?
Cam is up top. One on passenger is exhaust. One on driver side is intake. Crank sensor is down low in the back near the starter and transmission bell housing.
Old 12-18-2016, 02:48 PM   #12
The Snake
My Ride: 3 Pedal 330
Camshaft sensor on the intake is an easy DIY. only tool I had to buy is a 32mm wrench. Also having one of those flexible grabbers helped a lot with running the wire.
"If you aren't driving a stick shift BMW, you're just steering"
The Snake is offline   Reply With Quote
Old 12-18-2016, 02:51 PM   #13
WDE46
No. like I said Siemens or Genuine only
Old 12-18-2016, 02:57 PM   #14
The Snake
FCP euro has a sale on the Febi (OEM) for 50$. I bought/installed it and it was clear that it was a genuine BMW one with the logo scratched off. Any reason why this wouldn't be as good as Siemens or Genuine?
Old 12-18-2016, 03:27 PM   #15
WDE46
Febi isn't the OEM or even AN OEM on the E46. It might have been a mislabel on FCP or they're just reselling Siemens/BMW sensors.
Old 12-18-2016, 04:29 PM   #16
orb
orb's Avatar
My Ride: 325Ci
No reason to get from FCP if they don't carry Siemens. I know everyone here loves them, but even with the lifetime warranty you're still spending more for an inferior part with an increased chance of being stranded. No thanks, 2 year warranty is good enough.
Old 12-18-2016, 04:37 PM   #17
The Snake
I just checked. The brand is listed as OEM- the reason I was confused was because it came in a Febi box for some reason. There is most definitely scratching off where the BMW logo would be though.
In my opinion, given how easy and quick the job is, no reason not to get this one with the lifetime warranty and replace it if it starts giving problems again.
Old 12-18-2016, 04:53 PM   #18
WDE46
When they say OEM they mean it. Sometimes they can't put the brand due to sales agreements but OEM is accurate.
Old 12-18-2016, 09:02 PM   #19
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
The original cam shaft sensor that came from Germany in my 2003 330i was stamped FEBI with a BMW part number also. When I sought out a replacement a few months back I ordered "Genuine" - which was also listed as FEBI. Like many parts, to avoid production interruptions due to supplier issues there may have been multiple oe suppliers.
There's a thread on here from 4 years ago asking this very question that ordered several oem cps from pelican etc by various members. They all came in Febi packaging with the rounded scraped off.
BMW-North E46 Electric Fan Guide
Download a clean working copy of BMW Standard Tools with Special Tests for e46 :
Single NRG file: Complete BMW Standard Tools Suite You will also need ISO Workshop (free edition - linked) to create the install directory (image) or disk. NRG file: 347,183 Kb
BMW-North is offline   Reply With Quote
Old 12-19-2016, 04:54 PM   #20
OnTheFence
I always assumed Febi was some cheapo repro brand like Uro (not to bash Uro, I have a few Urop parts I've been happy with)
Never realized Febi was an OE supplier
camshaft position sensor, check engine light, codes, sensor
