Old 12-19-2016, 05:41 PM   #1
rtn28
My Ride: 00'328CI
Fuel pressure issue
2000 328Ci
Fuel pressure is at 20 psi with key on, jumps to 47psi when running, then back to 18 0r 20 psi when i turn off the engine. Vaccum line is good to fpr!!
My first guess would be check valve in fuel pump, but then the 3/2 valve thingy where the fpr is mounted draws my att.
Does the flow direction valve act as a check valve for holding pressure??
Does the fpr act as a check valve for Holding pressure??
Does the fuel pump have a check valve??
Is there a Check valve inline somewere??
Any accurate answers would be much appreciated!!
rtn28 is offline   Reply With Quote
Old 12-19-2016, 05:50 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Replace the fuel pump, it needs replacement regardless if this is the issue or not.
I do not bother to even check fuel pressure on cars over 8 years old, I just replace the fuel pump - Fuel pump failures - http://forum.e46fanatics.com/showthread.php?t=929501
Old 12-19-2016, 07:46 PM   #3
rtn28
My Ride: 00'328CI
I agree about replacing it, but... if the fuel pump is not the issue, that would suck, because i cant afford to just throw parts at it.
Old 12-19-2016, 07:57 PM   #4
jfoj
Fuel pump should have a check valve.
Fuel pressure regulator should also hold fuel pressure as well on the other end of the fuel line.
Fuel Pressure Regulators rarely fail and when they do it is usually the diaphragm and they leak through the hose connection.
EVERY E46 needs a new fuel pump by now.
Old 01-03-2017, 01:26 PM   #5
rtn28
My Ride: 00'328CI
New fuel pump, same problem. Waiting on regulator
3/2 valve, fuel pressure, fuel pressure regulator, fuel pump
