BMW E46 Missfire cyl (1-6) m52 (Solution) - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-26-2016, 11:27 AM   #1
Ne70
My Ride: E46 323ci
Hello there'
I was whit this error in my M52 E46 323ci
check the errors over here:
DME -> E4/B2 - Ox.-s.control deviation, bank 2, too large
CB/B2 - Ox.-sensor control, bank 2, control limit
E3/B1 - Ox.-s.control deviation, bank 1, too large
CA/B1 - Ox.-sensor control, bank 1, control limit
EE/B4 - Misfire, cylinder 1
F2/B7 - Misfire, cylinder 5
F0/B5 - Misfire, cylinder 3
F3/B7 - Misfire, cylinder 6
EF/B4 - Misfire, cylinder 2
F1/B7 - Misfire, cylinder 4
I was almost going crazy with all those issues, lack of power, a lot of misfire, and low/high rpm
the solution? pretty easy:
before buying a lot of stuff: new coils, plugs, conectors, harness, fuel pump, etc, etc, etc
I try with the DISA valve
I buy a new one, and problem solved... NO errors
but wasn't a problem with the disa flap, was a problem with the disa vacuum
check this video, this guys explain the most common issues:
Don't waste too much money changing a lot of stuff... If youre having misfire in all the cyl, try with another DISA valve
Also my check engine go away with this new DISA valve, and the car runs smooth
Hope It helps...
Ne70 is offline   Reply With Quote
Old 12-26-2016, 08:13 PM   #2
Yankeebmwgirl
My Ride: 2001 BMW 325xiT
Send a message via ICQ to Yankeebmwgirl
We replaced the disa with a used one when BMW north came to help us out. It had been mentioned that maybe the o ring needs to be replaced because I got a lot of cold start misfires still happening.
Sent from my SAMSUNG-SM-N900A using E46Fanatics mobile app
Yankeebmwgirl is offline   Reply With Quote
Old 12-26-2016, 08:51 PM   #3
jmo69
My Ride: 03 325xi 98 328is
I wonder if the fact that I had my Disa out and back in when I did my starter was the reason the first start had multiple mis-fires. A restart smoothed everything out and it hasn't happened since.
][/2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
disa, e46, misfire, valve
