Old 01-16-2017, 11:37 AM   #1
imallthewayup
My Ride: 330i
Alternator, Or Batter?
Hey guys,
So i drove my car about 10 miles and started and drove good. Then i stopped at the store and when i went to turn my car on it stuttered, was about to start but died. I jumped it and it drove good, went to autozone and they said it was a bad alternator. Next day i jumped it and it drove fine so i was wondering if it is really the alternator or the battery or something else. Just want some advice before i get a new alternator or battery
Basically:
- Car not running: 9 v
- Car running: 14 v
- When jumped it starts right up and when i shut it off it starts right up. Doesnt start after sitting after an hour
- Dont drive the car much, maybe 30-50 miles per week
- When driving car runs fine
Also not sure if its related or not but ac only works when i drive on higher speeds it starts blowing cold but other than that nothing blows out, and i have the brake light on and exclamation on dash but those have happened a month or two ago.
Thanks!!
imallthewayup is offline   Reply With Quote
Old 01-16-2017, 11:42 AM   #2
Clovett
My Ride: 330ci
Originally Posted by imallthewayup View Post
Hey guys,
Basically:
- Car running: 14 v
Thanks!!
Sounds like a bad battery to me. If it jumps to 14 volts from 9 volts when it's running it appears to be charging. If it's charging to 14 volts check the battery voltage when you first park it and see if it's not 12+ volts. If it is and drops to 9 volts over night either the battery is done or you have something draining the battery.
At that point check it when you park it for the 12+ volts then you need to be able to disconnect the battery and see if it's 9 or 12 volts the next day. Others can tell you the best way to do this and not lock yourself out of your car.
Clovett is offline   Reply With Quote
Old 01-17-2017, 03:51 PM   #3
imallthewayup
My Ride: 330i
imallthewayup
Thanks I will keep an eye on my battery. I have it full charged now and will see if something is draining my battery. This maybe a dumb question but are the windows supposed to roll down when the keys are out
Old 01-17-2017, 04:57 PM   #4
M_3_X
My Ride: E46M, 330Xi, E30, X3
- Car running: 14 v
^^There's your answer.
2002 ///M3 Coupe, Steel Gray, black leather, HK, 6MT.(01/2015-current)
2005 X3 3.0i ZPP, Htd seats, Htd strng whl, Black Sapphire on Terracotta.(08/2008-current)
1991 325i Convertible, 5MT, htd seats
2004 330Xi Orient Blue, 6MT, Sport, Premium - Son
1995 ///M3 Coupe, Luxury, MT, Htd seats, Cosmos Black.(11/2011-01/2015)
2003 325Cic Orient Blue, Premium (03/2007- 03/2010)
River City Bimmers - BMW CCA Chapter
M_3_X is offline   Reply With Quote
Old 01-17-2017, 05:45 PM   #5
imallthewayup
My Ride: 330i
Im a little retarded, does that mean it is the battery? I charged my battery and today it was running good, staying at about 12.4 V
Old 01-17-2017, 05:48 PM   #6
tommy d
My Ride: 2005 330i
yes, battery needs to be min. 12V
tommy d is offline   Reply With Quote
Old 01-17-2017, 05:50 PM   #7
imallthewayup
My Ride: 330i
ok thank you
Old 01-18-2017, 11:02 PM   #8
imallthewayup
My Ride: 330i
Today I was driving it around and when I went to park it within 2 seconds the battery light flashed on and I died. Then I waited about 2 hours and was able to drive it home, without stopping on any lights. Now I'm sitting in my drive way and the volts are constantly jumping all over the place woth the car staying on from 13-14.5 v, my lights are lightly flashing and the engine is slightly bogging but staying running. When the car is parked it's at 11.4 v and I'm able to turn it on.
Also I do notice that if I turn off the car with the lights on and stuff and let it drop to about 11.5 when I turn on the car it drops to 9v then jumps to 14 v. Im provably over thinking this, anyway I just bought an alternator hope that fixes it.
Old 01-18-2017, 11:09 PM   #9
shiftyshadow17
My Ride: 2003 325xi
you should charge your battery too.
shiftyshadow17 is offline   Reply With Quote
Old 01-18-2017, 11:11 PM   #10
imallthewayup
My Ride: 330i
Yeah I just charged my battery overnight but not full
alternator, battery
