Old 01-20-2017, 04:31 PM   #1
patmappas
My Ride: 325xi
Misfire on all cylinders
Hi guys
I have misfire codes
PO300
PO301
PO302
PO303
PO304
PO305
PO306
I have an engine knocking and it sounds like it's coming from the intake manifold. I think what happens is one cylinder misfires then they all. I've replaced the Disa and CCV lines which took care of the lean codes I used to have. I've also replaced the MAF. Any ideas on how I should diagnose this problem? I can also post a log.
patmappas is offline   Reply With Quote
Old 01-20-2017, 04:52 PM   #2
Bigc2016
My Ride: 328i
Bigc2016 is offline   Reply With Quote
Old 01-20-2017, 04:59 PM   #3
CylonRed
My Ride: '01 E46 330i sport
See this thread for what you need to do:
http://forum.e46fanatics.com/showthread.php?t=1120859
CylonRed is offline   Reply With Quote
Old 01-20-2017, 05:00 PM   #4
Dave1027
My Ride: '06 IR zhp coupe
If the knocking is coming from the intake manifold I'd suspect the disa. You should pull it out and give it a good inspection.
Old 01-20-2017, 05:02 PM   #5
jfoj
My Ride: 330CiC, M5, X5, E93
What happens when the MAF is disconnected??
Did anything change when the MAF was changed?
Brake booster leaks do not get picked up with a smoke test.
What is the MAF value @ idle?
What are the Fuel Trim values @ idle?
Old 01-20-2017, 05:18 PM   #6
patmappas
My Ride: 325xi
When the Maf is disconnected the idle changes. I drove around with the Maf unplugged for 10 minutes and afterwards check OBD fusion and had pending codes for all cylinders but no actual confirmed. I plugged the Maf back in while the engine was running and the car died. Turned the car back on with Maf connected and let it idle for 2 minutes and the the codes came back on confirmed
The car idled smoother than before since I've had the Maf replaced
Here's my log
https://www.dropbox.com/pri/get/Apps...LJFnwi-v2r4pNg
Old 01-20-2017, 10:19 PM   #7
swordsman11868
My Ride: 2003 325i
Here's my log
That link didn't work for me...
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is online now   Reply With Quote
misfire, misfires
