Old 01-26-2017, 12:59 PM   #21
My Ride: Lexus
You may be able to mitigate oil loss on some old BMWs, but truth is, at some point, these old BMWs are just going to need new ring jobs. Plain and simple. Everyone wants to believe there's a magic quick fix. but there's not. These engines are just fvcking old and worn. You want new car characteristics, you'll have to make your car brand new OR get a new car. Stuff wears out.
Money money money.
Old 01-26-2017, 03:39 PM   #22
das_autobahn
My Ride: 2004 330ci coupe
Originally Posted by mango View Post
you may be able to mitigate oil loss on some old bmws, but truth is, at some point, these old bmws are just going to need new ring jobs. Plain and simple. Everyone wants to believe there's a magic quick fix. But there's not. These engines are just fvcking old and worn. You want new car characteristics, you'll have to make your car brand new or get a new car. Stuff wears out.
Money money money.
ie: Replace everything mango fashion
das_autobahn is offline   Reply With Quote
Old 01-26-2017, 06:11 PM   #23
Megalocnus
My Ride: 05 330i ZHP/MT
Yes. You are unintentionally right.
At this point a ring job is likely to turn into a full blown engine rebuild. One example is 50sKid's findings after engine teardown. Initially he was planning a head gasket / piston rings / rod bearing job.
Just watched one of his most recent videos on blueprinting his engine block. He found that most of the cylinders have significant out-of-round and taper wear, so no simple cylinder wall honing and engine reassembly. He'll need cylinder boring machine job and a set of oversized pistons.
This is just motivating me to do leak down testing more often and get ready for a full engine rebuild at first sings of compression ring and/or cylinder wall wear.
Of course, people who just want to get another year or so out of their aged E46 may consider alternatives cheaper than restoring the engine back to factory specs.
Megalocnus is offline   Reply With Quote
Old 01-26-2017, 06:50 PM   #24
CalVol
My Ride: 2001 330i
Originally Posted by Megalocnus View Post
Yes. He found that most of the cylinders have significant out-of-round and taper wear, so no simple cylinder wall honing and engine reassembly.
Interesting... wonder if this is due to the cast iron inserts not being very durable or the way in which they are manufactured (pressed in?)
CalVol is offline   Reply With Quote
Old 01-26-2017, 07:47 PM   #25
daves325in2012
My Ride: 2004 330cic
I am surprised from those consumption rate you reported OP!!
Almost feeling spoiled that @ close to 140,000 I am down MAYBE 1/4th of a quart in 3,500miles on my B30.
There's got to be some variable here which you can compare again a non-burning car, which is affecting the consumption ; Have you smelled the exhaust lately for oily smell when you step on it, or trailed your car with a camera lately?
Mysticblau 330cic
Pretty Facelift on..PSS9\\Alpine 9855\\More
daves325in2012 is offline   Reply With Quote
325xi, oil consumption
