Old 01-31-2017, 04:03 PM   #1
rako92
My Ride: E46 318i M43
E46 Cruise Control Does not Work
Hey guys. I have issue with my cruise control (E46 old style, mechanical). Until couple of weeks ago it was working fine. Now, the green light on the dash stays on until I press the + button. Then it does not keep the speed and some seconds later the light turns off. I cannot switch it on with the I/O button until I stop the engine and start it again (or turn the ignition). Any ideas?
rako92 is offline   Reply With Quote
Old 02-01-2017, 10:24 AM   #2
markusmarkus
My Ride: 2001 330Ci
The DME/ECU controls the cruise control. The DME/ECU won't allow the cruise control to operate when the MAF is acting up. Have the DME/ECU scanned for codes and post them.
Old 02-01-2017, 10:28 AM   #3
rako92
Okay. I had my MAF replaced as it was faulty and was showing as an error code, since then I never got that error again and the cruise was working fine. I will try to scan tonight in case there is something new and will reply. Thanks
Old 02-01-2017, 11:05 AM   #4
rako92
P0420 is what appeared as error code (pending) and I cleared it. Now there are no faults logged or pending, but the situation is the same. It is the only diagnostics I have available to use today.
Old 02-01-2017, 12:38 PM   #5
Geo31
Ironman
My Ride: 98 M-Z3, 01 325iT
I am not sure about the E46, but my E36/7 will not allow the cruise control to operate if there are any codes. Check your codes again and see if it came back. Some codes you have to drive a while to completely clear them IIRC.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Brag: For the rest of your life
Geo31 is offline   Reply With Quote
Old 02-01-2017, 04:50 PM   #6
rako92
Actually, after a couple ot starts and stops of the engine (and after the initial clearof the fault), the cruise seems to work again :-) I will have a look what is this code and will have the car serviced in case it is something important, but as it causes the cruise to stop working, I suppose it is something important. Thanks, both.
Old 02-01-2017, 05:56 PM   #7
Geo31
Ironman
The code is CAT efficiency (I looked it up before I responded earlier). Yeah, I think some codes need to be cycled something like 3x before it's completely clear.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Old 02-12-2017, 05:37 AM   #8
rako92
Update, guys. Since the cruise worked twice I never had the opportunity to drive with thos car on a road that I can test it again, only urban. Now it does not work again... Checked it with INPA yesterday, no fault codes at all. The brake lights are fine. The MAF is fine as well. No pending faults... The light comes on (although the cruise does not work, the speed just drops) but when I press brakes it goes off and never switches on again before I start the engine again. Found other topics with this issue, but I have checked all the reasons discussed and it seems it's neither of them. Any further options?
Old 02-12-2017, 09:56 AM   #9
Geo31
Ironman
What were the other issues you checked out? It helps to narrow things down.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Old 02-12-2017, 10:01 AM   #10
rako92
As I said, there are no fault codes (no pending as well), the MAF is new and seems it is ok as well. The brake lights work so this is not the cause as well. As it is 2000 model it is not electronic and uses the mechanism to physically control the throttle, I checked this and nothing is stuck, for example. However, when I use brake, the cruise light goes off. And it does not work even when the light is on. I dont know what other issues may be the cause to check them out as well
Old 02-12-2017, 10:25 AM   #11
Geo31
Ironman
Sounds like the electronics are working correctly, as least on the surface. I've not looked at our cruise control closely, but is the 2000 unit a vacuum controlled unit (my older cars had vacuum controlled units).
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Old 02-13-2017, 08:51 AM   #12
markusmarkus
My Ride: 2001 330Ci
What brand is the new MAF?
Old 03-25-2017, 12:37 PM   #13
rako92
Hi all, sorry for the delay. Haven't got enough time to keep on digging.
I am not sure if it is vacuum controlled, but it is the Drive-by-Wire type.
The new MAF is Bosch.
The motor below the hood is buzzing, no matter if the cruise is switched on or not, it is enough to have the car started or the ignition to be on.
However, still when I press I/O, then reach say 80kmh and press +, the speed keeps dropping. When I involve brakes, the green light turns off and I can't switch it on with the I/O before the next start of the car... I don't know what else to check. No fault codes (including Pending)..
Old 04-04-2017, 03:37 AM   #14
rako92
Run a check with INPA last night. There is one error that shows up for the Cruise Control module (FGR2_5):
17 Stellglied hat max. Abschaltzeit ueberschritten
After I clear it, it appears again.
I am not quite sure what it means. In Google I found only one (literally!) result with exact same text, it is not useful at all.
Any ideas?
Old 04-04-2017, 12:21 PM   #15
rako92
Here is a video of the actuator opened:
It works/buzzes any time, no matter if the green light is on or off. I think the issue is that both the parts are not being connected together when needed (should it be when I preas the + button?) And that's why the error comes up and the cruise does not engage.
cruise control, e46, tempomat
