E46 Xi Forum
Old 02-04-2017, 12:29 AM   #1
Gbro
My Ride: 2004 E46 325xi
Time for engine #3...
So as the title says, my 2nd engine that I put in my 2004 325xi has gone. R.I.P.
I debated on putting this in the engine swap forum, but decided to stay here.
I believe the head gasket has gone unfortunately, I will make a different thread somewhere else discussing why I believe this to be true. Then I will post the link on this thread later...
So, my question is. Can I just buy a RWD "I" engine and swap over the components? What needs to be swapped over?
Off the top of my head:
Oil pan
Pickup tube
Differential
Axles Obviously...
Dipstick?
What else am I missing?
I can just run the XI DME right, that part is fine, no need to tamper with?
If anybody has done this I would appreciate some clarification, I have searched around but found no defiant answers.
Thanks in advance,
-Gbro
Gbro is offline   Reply With Quote
Old 02-04-2017, 04:14 AM   #2
inline.6ix
My Ride: 2003 330xi
Well i know for the 330xi you can swap the engine from an i. You'll just have to change the oil pan and the dipstick, i believe. Other than that, as long as it's the same engine code (i.e: m54b30 ) then you shouldn't have to change any electronics. If you have the extra cash you should look into swapping a 3.0 in there. Shouldn't be a a major jump in price besides getting the ecu, Dme, etc.
Correct me if I'm wrong guys, this is my first post lol
Sent from my LG-H918 using E46Fanatics mobile app_nr_
inline.6ix is offline   Reply With Quote
Old 02-05-2017, 06:48 PM   #3
shane528i
My Ride: 330i ZHP
Same problem looking for advice
Need some advice
Subject: 2004 325XI
In the middle of a 4 hour drive today, I lost compression in #6 cylinder
after diagnosing looks like Head needs to come off. Car has 180K
and is in great shape & always well maintained.
is it best to redo head, Or try and find a low milage engine?
also, approx time to do both jobs?
I havenít been able to find any post on engine swaps for the XI.
Thanks, Shane
shane528i is offline   Reply With Quote
Old 02-05-2017, 07:05 PM   #4
Tippey764
My Ride: 2002 Touring
Send a message via AIM to Tippey764
Yes you can just get a RWD engine
All you need to swap is
Motor mount arms
Oil Pan
Dip stick tube
Everything else will be able to bolt right up.
You might want to take this opportunity to buy a 330 engine to replace your 325 engine. Its a direct drop in and they can be had for the same amount of money these days as a 325 engine.
Tippey764 is offline   Reply With Quote
Old 02-05-2017, 07:15 PM   #5
BMWM3186
My Ride: 1992 F150
How have you needed 3 engines within 180k?
BMWM3186 is offline   Reply With Quote
Old 02-05-2017, 07:32 PM   #6
GCoop
My Ride: '04 325xi
Because racecar
GCoop is offline   Reply With Quote
Old 02-08-2017, 02:13 AM   #7
Gbro
Thanks for the response.
I would but then, I would have to get the transmission and the Front and Rear diffs. I think the transfer case is the same though. If I could find a whole parts car I would.
Motor mount arms
Oil Pan
Dip stick tube
Thanks for the response...^^^
I was thread jacked lol. Car had about 247K when it blew the head gasket, then swapped another in with about the same mileage because I had it laying around, and now it needs another one (Head gasket again I suspect)... I will definitely get a lower mileage one this time around.
Originally Posted by GCoop View Post
Because racecar
You caught me haha
Old 02-08-2017, 03:46 AM   #8
Gbro
Here is the link to my other thread on the engine/cooling system failure.
http://forum.e46fanatics.com/showthread.php?t=1122241
3rdtimesthecharm, fml, swap, xi
