Camber Plates Blocked By Shock Tower - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 02-07-2017, 11:15 PM   #1
GoodEnough
My Ride: '06 & '11 M3 ZCP
I just installed my ST XTA Coilovers, and the camber plate seems to be blocked by the shock tower. My cars stock camber rods are set to max camber, so the camber plates are my sole adjustment for camber, but now its covered by the shock tower. Any one have any ideas on what I should do? Can the camber plates be adjusted to fit the hole? Anything? Let me know what you guys think.
Thanks.
2006 M3 ZCP - 2011 E90 M3 ZCP
GoodEnough is offline   Reply With Quote
Old 02-08-2017, 12:08 AM   #2
GoodEnough
Heres a pic to see what I am talking about
Old 02-08-2017, 02:18 AM   #3
Commando
My Ride: M3 - SMG
Its not clear what you are trying to achieve but at the end of the day the position of that strut end is what matters. It might be better to make the adjustments at the spindle if you need to get further away from factory.
Commando is offline   Reply With Quote
Old 02-08-2017, 07:18 AM   #4
SK330ci
My Ride: 02 330ci w/ 3 Pedals
Attachment 649911
Your picture looks like the drivers side, if im right you're running maximum positive camber. Fix it.
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 02-08-2017, 09:05 AM   #5
GoodEnough
Running maximum positive camber so my camber adjustment is solely in the camber plate. Removing the other stock adjustment. My wheels are at -1.5 roughly currently, not postitive. It's because the stock adjustment is fully maxed to negative
Old 02-08-2017, 01:26 PM   #6
elbert
My Ride: Chevy Beretta GTZ
Oh I see the problem -- it's the way your camber plates are designed. Looks like the only way to adjust the camber is to jack up the car, loosen or maybe completely unbolt the upper mount of the strut assembly from the car, adjust the plate, then reinstall the upper mount.
Most of the better camber plates have a separate slotted plate, so all you need to do is loosen the 3 strut mounting bolts and slide the mount around without having to remove/uninstall anything.
I would not cut up your strut tower, that lip is there for strength. Nor would I leave out any of the bolts.
2004 E46 M3
2015 WK2 JGC
2001 E46 325iT
elbert is offline   Reply With Quote
Old 02-08-2017, 09:20 PM   #7
GoodEnough
Yeah I believe that is he problem, the KW camber plates have the same problem - thanks!
camber plates, coilovers, shock tower
