Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Complete Cars - Private
Old 02-08-2017, 10:39 PM   #1
Brooks_Church
My Ride: S14 SR20
Imola ZHP 6spd
Plan was to continue moving forward and install diff and
Become more of a track car, but it's too nice of a car to continue down that path.
Imola exterior, Black leather interior, 6 speed transmission, 127,800 miles.
Purchased October 3rd 2015 from Miami, FL with 104,900 miles. Now in Columbus, OH. Has only seen 2 months of winter and was garage kept and washed very often to keep salt off car.
Car has been stored in garage before first snowfall this winter and almost always garaged.
Engine-
AFE Intake with dry filter (installed previous)
Shark tune (Feb 16) 200whp/194wtq on Dynotech Dyno at Tuner Tools (roller /heartbrake dyne)
Idler pulley, hydraulic belt tensioner, AC belt tensioner, alternator hydraulic tensioner, alternator Roller, DISA (Dec.15)
AC & PS/WP/Alternator Belt (Dec. 15)
Power steering reservoir and fluid flush (Dec.15)
Muffler delete (Feb 16) with Vibrant double wall slash cut Tip 3';
Coolant expansion tank, thermostat, coolant level sensor (Dec. 15)
Replaced MAF, EVAP pump vacuum hose (Dec. 15)
CCV/ cold weather kit; (ECS), IACV grommet, Intake manifold gasket, dipstick o-ring, hard coolant lines (under intake manifold), ALL soft coolant lines, clean oil dipstick tube, Clean IACV, Clean throttle body/ inspect gasket (May 16)
M3 motor & trans mounts mounts, magnet oil drain plug (May 16)
Fuel pump (delphi with lifetime warranty NAPA) (June 16)
Upper & lower intake boot with metal joint and F connector (Aug 16)
Suspension/ Wheels
Fortune Auto 500's ,Swift springs, and roller bearing upgrade, standard spring rates (Apr 16)
Whiteline front sway bar end links (June 16)
Powerflex FCAB (May 16)
Z4 M RTAB with ECS eliminators, rear control arm bushings, rear trailing arm bushings (July 16)
Stud conversion kit (70mm+) ECS (Jan 16)
Rear strut mount reinforcement plate/ ECS (Oct 16)
Apex ARC-8 18x9.5 +35 with 235/40/18 Kuhmo PS91's(Aug 16)
Brake
EBC yellowstuff brake pads, centric zinc brake rotors, painted black calipers (May 16)
Goodrich stainless brake lines, stainless clutch line (ECS), Motul RBF 600 brake fluid (Apr 16)
Exterior
Matte black kidney grills (previous)
RCR tails, clear turn signal, clear side marker & LED license plate light (Mar 16)
Yellow fog lights (whole assembly) (May 16)
Fender roll front and rear (Jul 16)
Interior
Leather M3 steering wheel (Oct 16)
Onyx black padded suede headliner, A/B/C pillars (Mar 16)
Weather tech floor mats (F&R) (Jan 16)
CD53 w/ mediabridge (bluetooth media, phone), Sirius sat. radio (Nov 15)
Colby shift boot, e-brake boot in black suede with tri-color stitching (Jan 16)
Window regulators all 4 corners. URO with lifetime warranty.
Full LED interior lights (Mar 16)
Paint is about 7.5/10 with some clearcoat peeling on side mirrors, door handle, and small spot on hood of vehicle. As well as some rock chips on front, slight scraped on bottom of front bumper, slight fade of shadowtrim, and some scratches on trunk from sat radio antenna.
Interior is in great shape. Steering wheel has slight scrapes on it (ring) and passenger door speaker cover is partially broken (doesn't affect speaker).
Car has a small oil leak from oil pan gasket.
SOLD!
Car has Lien, but clean title. No trades. Willing to help arrange delivery/ transport.
https://columbus.craigslist.org/cto/5986721505.html
ID:	649964   Click image for larger version
ID:	649965   Click image for larger version
ID:	649966   Click image for larger version
ID:	649968   Click image for larger version
Brooks_Church is offline   Reply With Quote
Old 02-15-2017, 11:32 AM   #2
orb
orb's Avatar
My Ride: 325Ci
Beautiful car and can vouch great seller (bought my exhaust from him). GLWS
orb is offline   Reply With Quote
Old 02-21-2017, 08:39 PM   #3
Brooks_Church
My Ride: S14 SR20
Took her out for a drive on the beautiful weekend. This car needs a good home!
Old 02-23-2017, 04:30 PM   #4
Brooks_Church
My Ride: S14 SR20
When I first took her home.
Old 02-27-2017, 08:50 PM   #5
Brooks_Church
My Ride: S14 SR20
Old 02-27-2017, 09:08 PM   #6
GmbH
My Ride: 2001 M3, ZHP 330i
Way overpriced for the mileage.
GmbH is offline   Reply With Quote
Old 02-27-2017, 09:33 PM   #7
Brooks_Church
My Ride: S14 SR20
You buying? If you are, make me a offer. If not, go troll somewhere else.
Old 03-01-2017, 12:24 PM   #8
BrownMagic
My Ride: E60 M5|E83 X3|P38 RR
I'm also keeping an eye out for a ZHP, but I agree. Overpriced and I'm not sure this is even a factory ZHP...
I would have you confirm by providing the VIN if this is a real ZHP or not; however, we are too far apart on price for me to waste your time looking into details.
BrownMagic is offline   Reply With Quote
Old 03-10-2017, 04:42 PM   #9
Brooks_Church
My Ride: S14 SR20
Sold!
imola, manual, ohio, sedan, zhp
