Old 02-11-2017, 12:40 PM   #1
Raqib
My Ride: Bmw 325i 2001
Car won't start but cranks after converting to hids
HI, I have a 2001 325i, and I came home and I shut the car off and I Installed some hid's. after doing so, I went to start the car and it would crank but won't start. I checked all the fuses and they're good, I changed all the fuses in the ECU in the engine bay, in the black box. Also my battery is new and I had it hooked up to a jumper pack and i tried jumping it with an suv. Also, my fuel pump is good, I can hear that kick on. I don't know what to do now. Please help.
Raqib is offline   Reply With Quote
Old 02-14-2017, 10:21 AM   #2
MikeBMWE46
My Ride: BMW E46 318i
Just to be clear, did you remove the hid and try starting the car again? You could try disconnecting the battery and after a while reconnect it and retry. If this does not work, then there is a chance something is wrong with the ECU or the ignition system. Did you splice any connectors directly to the ECU or anywhere else? If that is the case, you might have connected to the wrong cable and caused some kind of damage. If nothing from the above works out, you should get the car properly diagnosed. Finally, i'd be interested to know what caused the problem once you find out.
Hope i've been helpful and good luck,
Mike
MikeBMWE46 is offline   Reply With Quote
Old 02-14-2017, 10:28 AM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Engine may be flooded. Common problem with these cars.
http://forum.e46fanatics.com/showthread.php?t=1063462
http://forum.e46fanatics.com/showthread.php?t=1069117
http://forum.e46fanatics.com/showthread.php?t=1112112
http://forum.e46fanatics.com/showthread.php?t=1117576
http://blog.bavauto.com/17656/it-hap...king-no-start/
Old 02-14-2017, 12:45 PM   #4
Raqib
So, I did get the car started, it was a fuel relay behind the fuse box. The problem I'm having now is that it idles rough and it shuts of if I don't press on the accelerator
Old 02-14-2017, 12:48 PM   #5
jfoj
Old 02-14-2017, 06:35 PM   #6
Raqib
Ok so I just took part my EVAP Purge Valve (a.k.a. Fuel Tank Breather Valve), and theres two hoses and one broke off from the back while i was trying to pull it off. I need help on knowing where the hose goes so i can put it on since it goes somewhere into the engine bay.
325i 2001, e46, won't start
