Old 02-20-2017, 06:16 PM   #1
Mr Scorch
My Ride: 2001 316ti compact
A lot of issues
right i just bought a 2001 e46 316ti compact as a project car and it has issues.
so far ive found out
car siren is constantly going off
key fob dont unlock or lock car doors and wont open the boot (trunk)
console button dont unlock it either
head unit dont work
window wipers dont work
window washer dont work
thats all ive discovered so far .
i know its bad but ive disconected the battery to save my neighbours from banging on my door at 2am
PLEASE HELP with any ideas of what could be causing all of this
Mr Scorch is offline   Reply With Quote
Old 02-20-2017, 06:49 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Alarm going off may be due to the faulty hood/bonnet switch, disconnect the hood/bonnet switch and see if the alarm stops going on.
Keyfob may be bad, you need to have it tested to see if it is putting out signals.
The GM5 module or relays may be bad, www.bmwgm5.com
But before you go down the path too far, make sure you inspect and check for blown and misplaced fuses as this may be part of the problem.
Old 02-21-2017, 05:31 AM   #3
Mr Scorch
how do i disconnect the hood switch and where is it located?
Old 02-21-2017, 06:22 AM   #4
jfoj
Might not be an E46, but check this out - https://www.google.com/search?q=BMW+...Z9Lt_WimoBMCM:
http://forum.e46fanatics.com/showthread.php?t=754582
Google Search is your friend.
Old 02-21-2017, 11:59 AM   #5
Mr Scorch
edited first post
Old 02-21-2017, 12:04 PM   #6
Mr Scorch
also thankl you for helping me out with the most stupidest questions .
battery, electrial, issues, key, lock
