Old 02-21-2017, 01:51 AM   #1
BimmerBoss46
My Ride: 325ci coupe m-sport
Bmw 325ci differential help
Hello everyone,
The Differential in my 2002 325ci manual 5 speed is on its way out. I am having trouble finding out the ratio that I have.
Will a diff from an automatic 325ci work or will the ratios be too short. Any help would be appreciated
BimmerBoss46 is offline   Reply With Quote
Old 02-21-2017, 02:21 AM   #2
Sjoerd
My Ride: BMW E46 328i
Stock ratio is 3.23 . Automatic is 3.38. Its a small difference. However a shorter ratio will make the car a lot more fun
Sjoerd is offline   Reply With Quote
Old 02-21-2017, 08:36 AM   #3
shanneba
My Ride: 2003 330Ci
Here is a calculator that will help you determine the RPM difference.
http://www.bokchoys.com/differential...calculator.htm
Here is another link to the same site that shows the diffs used in the various US BMWs- not sure if AUS is different- it shows the 325Ci manual as a 3.15 ratio
http://www.bokchoys.com/differential/GearRatios.htm
Join BMWCCA
Old 02-21-2017, 09:44 AM   #4
goodmanr
My Ride: 01 325i Sprt&PremPkg
The ratio should be stamped or printed on top of the diff, but you probably can't see it while it is installed. My 2001 325i auto has a 3.46 ratio. Going from a lower number to a higher number will improve your acceleration and decrease your top speed.
goodmanr is offline   Reply With Quote
325ci, diff, manual, ratio
