Multiple cylinder misfires - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-24-2017, 04:03 AM   #1
Nexjan
My Ride: Bmw 328i
Hey how's everyone doing today,
I have an issue that i just dont know who to turn to anymore to resolve this problem, i have a 99 bmw 328i, 175k miles runs and drives but ive been in a bit a pickle lately with my baby, when i press the gas pedal she doesnt seem to respond to how much gas im giving it and lags its way up on the meter until it clicks and it just takes offf, it also shuts off often when i make stops (like at a red light) there are mutiple cylinder misfires so decided to change all 6 coil packs and all 6 spark plugs and that didnt seem to change anything, i also changed the timing belt and no better results.... is there anything else that could be causing this misfires?
Nexjan is offline   Reply With Quote
Old 02-27-2017, 01:17 AM   #2
zigoapex
My Ride: bmw 325 xi
look for vac leaks around valve cover gaskets, especially the gaskets around the plugs, they could let air in or leak a little oil, causing a misfire,
2003 325xi > new plugs-O2 sensors pre cat replaced ccv valve and 4 hoses-S.A.P.hoses and intake plug-M.A.F-intake boot oil housing gasket water pump and belts-fuel filter-fuel pump-cleaned I.C.V.-throttle body-changed front differential oil--drivers side-axle-passenger side axle Front wheel bearings-front lower control arms-control arm bushings-Steering Rack Boots-alternator-rt front tie rod, front brake pads and rotors.
zigoapex is offline   Reply With Quote
1999, 328i, misfire
