Old 02-28-2017, 12:33 PM   #1
1am3
My Ride: 2001 BMW 325xi
shock/strut assembly
i have an 01 325xi and i am over due on shocks. when it comes to shocks i have absolutely no clue what im am talking about. but i know i want to replace the whole assembly. any recommendations for what to buy?
i would love to get a sport suspension and lower it a little, but at the same time i dont want to break the bank.
thanks for the help
1am3 is offline   Reply With Quote
Old 02-28-2017, 01:26 PM   #2
tritron
My Ride: 325i
Do you want to lower your car? There are sets on ebay for $280 for set of coil overs.
tritron is offline   Reply With Quote
Old 02-28-2017, 01:42 PM   #3
1am3
@tritron
my car is already fairly low due to my shocks being so shot. i would like it to be lower a little more than it is now, so yes. what all does the set include?
Old 02-28-2017, 01:44 PM   #4
tritron
My Ride: 325i
Originally Posted by 1am3 View Post
@tritron
There is link to one for $280 there are other choices all a way to $1000
http://www.ebay.com/itm/BR-Coilovers...1Yb65o&vxp=mtr
Old 02-28-2017, 01:48 PM   #5
hitbyastick
My Ride: 2002 325i
Yeah get the cheap eBay coilovers for your xi. That's the smart thing to do.
Erryboddy got a plan till they get punched in the mouf - Mike Tyson
hitbyastick is offline   Reply With Quote
Old 02-28-2017, 01:49 PM   #6
1am3
@hitbyastick
is that sarcasm???
Old 02-28-2017, 01:54 PM   #7
tritron
My Ride: 325i
Old 02-28-2017, 01:59 PM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
@hitbyastick
is that sarcasm???
It's not..... contact Rob43 if you want to lower your car with QUALITY parts
Old 02-28-2017, 02:05 PM   #9
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Please, please don't buy a $280 "eBay" coilover kit. They are a waste of time and money.
Here is the standard starting point: a new set of OE Sachs struts (front) and shocks (rear) will cost about $500 or more. That's just shocks and struts, and doesn't include springs which would be another $500. When your original suspension would cost $1,000+ to replace, what would you expect from a kit that costs about 1/4 that?
Add on new nuts, bolts, strut and shock mounts (if worn out), and that's easily another couple hundred bucks.
Sachs is the Original Equipment supplier. Bilstein are also a very good alternative. Good luck.
Old 02-28-2017, 02:13 PM   #10
Solidjake
Zero. Leaks.
Solidjake's Avatar
^ Shock mounts/washers will definitely need to be repalced due to rust if it's that old. I would replace every single that the goes onto the strut/shock. Not worth the hassle taking it all out, having the car on air and you're missing a part because you can't remove it from the old strut/shock
Old 02-28-2017, 04:49 PM   #11
jmo69
My Ride: 03 325xi 98 328is
What ever you buy, remember the xi suspension is different from the RWD cars and are not interchangeable. Lowering too much will wreak havoc with your front axles so contact Rob43 and use his recommendations.
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is online now   Reply With Quote
Old 02-28-2017, 04:58 PM   #12
76m2002
My Ride: 2002 325iT
I went with Koni sport shocks (yellow, single adjustable) and Eibach Pro springs and loved it on my 325xiT.
76m2002 is offline   Reply With Quote
Old 02-28-2017, 05:32 PM   #13
Geo31
Ironman
My Ride: 98 M-Z3, 01 325iT
I agree with Jake. In the front, replace everything but the springs (but pre-inspect the springs because some folks in areas of the country that experience rust have had springs break. It's not an epidemic, but it behooves you to check.
In the rear, inspect the springs and pads. Replace everything between the upright and the coachwork (shocks, boots, mounts, gasket).
If you want to lower the car there are good quality lowering springs available. You can also get coilovers, but the cheap coilovers...
Look, if all you care about is lowering your ride, any POS kit will do. If you care about performance or you care about ride, don't waste your money on cheap coilovers. You'll be wasting your money.
It's not a hard job, just time consuming. Plan on taking your time and don't get frustrated. It's actually easy enough. You'll want a floor jack and jackstands as well. I'm about to do this soon on my touring. I'm installing coilovers because I got a great deal on a truly brand new set (the box was still wrapped with the banding). I'm replacing everything already mentioned, in this case including the springs because they are coilovers. It's a little harder in the touring because the back end interior needs a lot of disassembly.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Brag: For the rest of your life
Geo31 is offline   Reply With Quote
Old 02-28-2017, 07:58 PM   #14
hitbyastick
My Ride: 2002 325i
@hitbyastick
is that sarcasm???
Yes
Old 03-01-2017, 01:28 AM   #15
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Please stop posting this nonesense. Spend some time learning and researching before you even suggest to others what they should buy. I've read all your threads and posts and am not impressed with your lack of knowledge.
///Mmmmmm...
Old 03-01-2017, 08:45 AM   #16
LouieLou609
I have eibach sport pro kit springs with koni suspension, great set up
LouieLou609 is offline   Reply With Quote
Old 03-01-2017, 08:46 AM   #17
LouieLou609
And perfect lowering height
Old 03-01-2017, 09:49 AM   #18
cvx5832
My Ride: 325Ci, 325Cic, C300
The reviewer looks like he's 15 and more excited about the stickers that came in the box.
cvx5832 is offline   Reply With Quote
Old 03-01-2017, 09:59 AM   #19
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
This. I practically vomited when I saw this
But for the OP, check out these links:
https://www.fcpeuro.com/BMW-parts/32...77&m=20&page=1
https://www.ecstuning.com/BMW-E46-32...ension/Shocks/
Do it the right way or don't do it at all
>IN SEARCH OF GRAY SEDAN SPORT SEATS<
lllRazorlll is offline   Reply With Quote
Old 03-01-2017, 10:56 AM   #20
LouieLou609
Young kids with mommy and daddy money lol
coilovers, shocks, springs, struts
