Old 03-13-2017, 12:37 PM   #1
rorymcdaniel
My Ride: 2003 BMW 325i
Front End Noise and Wheel Shake
My 2003 325i is experiencing some issues between 40mph and 60mph. I have not been able to reproduce the issue, but my wife is the one who drives this car most of the time. When the car gets above 40mph, there is a rhythmic thud that she says sounds like is coming from just behind the driver's side front wheel. The noise doesn't happen immediately, but usually after 10-15 minutes of driving in that speed range. She says the noise goes away once she goes above 60mph. When she drove it on Sunday afternoon, she said it was decidedly louder and the steering wheel shake decidedly more violent than when she had driven it on Friday night.
The front tires still have plenty of tread on them and appear to be wearing evenly. I used a digital meter to make sure they were properly inflated. This had no impact upon the noise and vibration.
Given the car's age, I know it needs new front control arm bushings. I was considering ordering a kit that has control arms, bushings, and tie rods, as these all likely need to be replaced anyway.
Are there any other likely candidates that this could be? I know that stuff all needs to be done anyway, but I'd hate to go through that effort and not have it fix the problem.
Suggestions are appreciated.
rorymcdaniel is offline   Reply With Quote
Old 03-13-2017, 02:20 PM   #2
Score
My Ride: 2002 330Ci
Next time it happens, stop the car and feel the rotors. I had a similar issue and it was a partially seized caliper.
Score is offline   Reply With Quote
Old 03-13-2017, 02:37 PM   #3
rorymcdaniel
What symptoms would I be looking for?
Old 03-13-2017, 02:39 PM   #4
Score
My Ride: 2002 330Ci
If one rotor is hot, then that caliper is the issue. I had three rotors at 60 degrees and one at about 275 degrees - I used an IR thermometer.
Old 03-13-2017, 02:45 PM   #5
cvx5832
My Ride: 325Ci, 325Cic, C300
Given the car's age and miles at this point I would replace the bushings at minimum and go from there. I have 2 E46's of the same vintage. No matter how nice the roads or how gentle I drive it I can't get past 55k miles without the bushing spilling its guts. So now they're an automatic replacement item at 50k.
Your mileage may vary, but I doubt you'd get significantly more than that.
Untitled
cvx5832 is offline   Reply With Quote
Old 03-17-2017, 10:24 AM   #6
rorymcdaniel
So I took it in to my local BMW mechanic and paid his diagnostic fee. Really glad I did. He found that the left control arm ball joints were bad and of course the bushings are shot. He also found that both the left and right calipers were sticking, but the left one was really bad.
The control arm repair I feel is pretty straight forward. For the caliper - should I try to rebuild or just replace the caliper? If replace, any recommended brands?
Old 03-17-2017, 10:44 AM   #7
Score
My Ride: 2002 330Ci
I got a rebuilt caliper through autozone - seemed to be good quality and has worked so far. If you go with your original plan to replace control arms and bushings and tie rods, I would also do sway bar bushings, end links, and shocks. When I had front end problems I tried to replace a few parts at first, and ended up having to replace everything, which I should have done the first time.
e46, front end noise, shaking
