ABS Light after engine off for 1 second - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-19-2017, 09:24 AM   #1
dimmu123
My Ride: e46 320D 1999 nfl
Hello!
I have a weird problem after i replaced the alternator (The old one was noisy).
For example, after i turn the engine off, the ABS light comes and stays ON for 1 second. Same applies for other lights from the OBD, if i have ASC disabled and High Beem or handbrake lights on, they are still on after i shut down the engine for 1 second. This didnt happened before i replaced the alternator.
The values are 14.3-14.5V with car on, and 12.6V with car off.
E46 320d , 1999
Edit:::**
Here is the video wih the problem.
https://www.dropbox.com/s/cn3vwew7ih...93639.mp4?dl=0
dimmu123 is offline   Reply With Quote
Old 03-20-2017, 07:41 AM   #2
markusmarkus
My Ride: 2001 330Ci
Hmmm, you did disconnect the battery when you replaced the alternator?
Try this BMW approved procedure:
- disconnect the ground/earth cable from the battery
- disconnect the positive cable from the battery
- short the cables together for 10 minutes
- reconnect the positive cable to the battery
- reconnect the ground/earth cable to the battery (sparks are ok)
- reset the clock
This forces all the electronix to perform a hard reboot.
markusmarkus is online now   Reply With Quote
Old 03-21-2017, 01:10 PM   #3
dimmu123
- reset the clock
Hi! Thanks for your reply
I tried this, but still no luck. The cables have been shorted for 20-25 mins.
Old 03-21-2017, 01:12 PM   #4
dimmu123
Any other opinions?
Old 03-26-2017, 01:31 PM   #5
dimmu123
Up
abs light on, alternator, sensor
