Thread Tools Search this Thread Rating: Thread Rating: 53 votes, 5.00 average. Display Modes
Old 02-04-2012, 03:52 PM   #41
M3DIY
My Ride: NA
Exclamation
Originally Posted by Honk_Few View Post
I found a nice alternative to this for anyone looking to DIY this part. According to my local BMW service department, if you find a used sensor that's from the same model as yours (body style, transmission, suspension set up), it doesn't need to be calibrated to the DSC computer; it works plug and play. As luck would have it, I found just that for $125. It's pretty easy to install. You don't need to remove the driver's seat but rather just unbolt it and move it backward. Then you just pop out the threshold and loosen the footrest. Then you fold forward the carpet. Location-wise, think of the sensor as being under the outer most velcro unit for the floor mat. It's in a heavy bracket next to a two-inch thick styrofoam piece that must be shoved forward to allow access to the bolts. After I installed the used speed sensor, my DSC light went off immediately. I drove to a gravel road where I had fun confirming that I once again have traction and stability control!
Does anyone know the particulars of this DIY? In other words could I get a used one that matched my cars specs but my car is 323i and the sensor that this came out of was a 330i would it still work? Thanks.
M3DIY is offline   Reply With Quote
Old 03-19-2012, 06:11 PM   #42
elpache
My Ride: 2000- 323it
Wow you guys are great . Thanks a lot for your knowledge and help
Mp
elpache is offline   Reply With Quote
Old 03-21-2012, 01:49 PM   #43
chris98891
My Ride: '16 X6 50i
Send a message via AIM to chris98891
Bump...I'm pulling codes:
5E3C Yaw rate sensor not plausible
5E38 Yaw rate sensor electrical failure
Does this mean I should replace the sensor? I plan on just reseating the plug first, but if it can just simply be reset with a steering wheel lock-to-lock turn, I'd like to try that as well. Also, do I HAVE to code a new sensor? Or will it recognize it automatically? I have access to INPA/DIS/GT1/SSS if needed, but don't want to mess around with it if I don't have to.
-Chris
chris98891 is offline   Reply With Quote
Old 05-26-2012, 09:58 AM   #44
325Ci Guy
My Ride: 2001 BMW 325Ci
Hello,
This issue has now come up on my '01 325Ci...I was driving along the expressway 70mph and the front left brake activated on its own (it felt like the ABS was kicking in) the car jolted to one side and the DSC and Yellow Brake Light are now illuminated. After extensive research I am beginning to think it is this Yaw Speed Sensor. I am just having a difficult time with the correct part number?? Does anyone know/have the part number I need to be searching for? (I am looking for a used one)
325Ci Guy is offline   Reply With Quote
Old 05-30-2012, 10:45 AM   #45
M2K
My Ride: 01 325i
I also have the same issue with my 2001 325cic.
When scanned via PASoft 1.4 the following error codes were pulled:
5E3C [24124] Yaw rate sensor not plausible
5E38 [24120] Yaw rate sensor electrical faulty
After extensive research on the forum and the web, it seems that the yaw rate sensor is called differently at different places (speed sensor, rotation rate sensor, yaw rate sensor, just to name a few). However, I have narrowed it down to 2 possible part numbers:
37146781405 - ~$88
http://www.ecstuning.com/Search/37146781405/ES242427/
34526754289 - $440
http://www.ecstuning.com/Search/34526754289/ES63112/
Honk_Few, can you please help us visually identify the correct part from the choices above? Thanks.
M2K is offline   Reply With Quote
Old 05-30-2012, 04:06 PM   #46
chris98891
My Ride: '16 X6 50i
Hey man, I was getting the error too. I just let it happen for like a week, it got hot outside, and all is well again. I honestly can't explain it, but I'm ok with it! haha
-Chris
Old 05-30-2012, 04:18 PM   #47
ngillan
My Ride: Is in a salvage yard
YAW TRICK YAW!!!!!!
'07 328i - Montego Blue
ngillan is offline   Reply With Quote
Old 06-10-2012, 06:24 PM   #48
Dippinwandy
My Ride: 325i
Same thing happened to me.
Dippinwandy is offline   Reply With Quote
Old 07-29-2012, 04:00 PM   #49
Dippinwandy
My Ride: 325i
An interesting note: According to Systron Donner's literature on this sensor, it has an expected useful life of ten years. Guess this means we'll be seeing more of these fail pretty soon.
Which is why we are seeing these fail on the older cars not the newer ones.
Old 06-02-2013, 03:13 PM   #50
mpereznoble
My Ride: 323i
My ASC light came on! Car started like missfiring. Dnt read the codes yet. But thats the only light showing.... Ideas?
mpereznoble is offline   Reply With Quote
Old 06-02-2013, 03:41 PM   #51
David McMahon
My Ride: '99 E38 740iL
I don't think ASC cars like mine and yours have a Yaw sensor, as we don't have DSC (the later Stability control system)
You need a code reader, just be careful which one you buy!
David McMahon is offline   Reply With Quote
Old 06-02-2013, 03:42 PM   #52
mpereznoble
My Ride: 323i
http://www.autozone.com/autozone/acc...questid=308614
Would thins work? Im two blocks away
Old 06-02-2013, 03:49 PM   #53
David McMahon
I think that could read basic codes (prolly emissions ones) but not the in depth ones.
Also our older cars need a 20-pin adaptor as our data plug is under the hood, and not the normal OBD II port
Old 06-02-2013, 04:16 PM   #54
mpereznoble
My Ride: 323i
Ok, ive just ordered the 1.4 bmw scan. Hope it works!
Old 06-02-2013, 04:27 PM   #55
David McMahon
Which one did you order?
Old 06-02-2013, 05:53 PM   #56
mpereznoble
My Ride: 323i
http://www.xcar360.com/bmw-scanner-1...scan-tool.html
This one
Old 06-02-2013, 06:26 PM   #57
David McMahon
This one failed for me today, (got it yesterday!) hoping to get a replacement, so far no E-Mail reply.
Old 06-02-2013, 06:30 PM   #58
lszlszx
My Ride: 1.8T, XC70
How did it fail?
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 06-02-2013, 06:44 PM   #59
David McMahon
Originally Posted by lszlszx View Post
How did it fail?
Well it worked fine yesterday, I read most of the modules, cleared my Airbag Error, today nothing!
Getting "Hardware not ready" errors most of the time, then after changing key position, USB ports and Cables, new install of XP, I still get the errors. Sometimes I get an IKE error too
Old 06-02-2013, 06:51 PM   #60
lszlszx
My Ride: 1.8T, XC70
Do you have another scanner to try to make sure your plug is working?
dsc, sensor
