Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Old 08-18-2011, 07:19 PM   #21
cheungp
My Ride: e46,e91
Funny enough I have my car failed to start after a park n fly for 5 days. Every one of us was in panic mode since we were in a paid parking lot at night. We stopped exit passing car to ask for jump starts. Some said don't have jumpers, and one VW tourage said the battery is under the driver seat. Lucky enough a lady willingly help us out with her 4 runner. I jump start at the battery terminal,forgetting there were a pair in the engine hood. It was the same scenario at the posts. Thanks a lot for her offering but in vain. Later on we called a friend of mine connected jumper inside the hood, "soaked" for 5 mins. and the engine turns. If there a footnote in the manual for jump start, "soak" for 5 minute is a must for novice like ME.
cheungp is offline   Reply With Quote
Old 12-14-2014, 02:12 AM   #22
Diog
My Ride: 2000 Z28
Anyone here changed they're Battery, and found they have No Interior Lights, Wipers, Power Locks or Windows?!?
I've heard the GM5 Module controls all of these! Yet - After having a good look and test of the Relays on the GM5, they ALL WORK!!
And I Tested the Fuses, too! All Work, AND I get 12V+ from All of them with a MultiMeter!
WTF is going on with my Car?!?
Diog is offline   Reply With Quote
Old 12-14-2014, 04:36 AM   #23
Alex323Ci
My Ride: M3 & 323Ci (sold)
And I Tested the Fuses, too! All Work, AND I get 12V+ from All of them with a MultiMeter! WTF is going on with my Car?!?
hmm, check your Ignition Switch
Old 12-14-2014, 11:20 AM   #24
Diog
My Ride: 2000 Z28
It Starts and Runs Fine....
It Starts and Runs just Fine.
Why would the Ignition Switch be at Fault, if it starts the car, turns-on the Radio, ect.?!?
Old 12-14-2014, 12:27 PM   #25
jdstrickland
My Ride: '94 325iC & '00 323i
Because there are several sets of contacts in the ignition switch, some work and some do not.
You have missed a fuse, two, maybe.
jdstrickland is online now   Reply With Quote
Old 12-14-2014, 01:01 PM   #26
The Snake
My Ride: 3 Pedal 330
My e46 never jumps from the remote terminals.... only from the battery.
"If you aren't driving a stick shift BMW, you're just steering"
The Snake is offline   Reply With Quote
Old 12-14-2014, 01:28 PM   #27
Stinger9
My Ride: '04 330Ci
Dead Car Battery should be read and saved in the glove box.
Old 12-14-2014, 01:38 PM   #28
jfoj
My Ride: 330CiC, M5, X5, E93
Get one of these and key it in the trunk - http://forum.e46fanatics.com/showthr...ght=jump+start
No waiting, connect up and start the engine.
Old 12-14-2014, 07:37 PM   #29
ca1242
My Ride: 2003 330i
Could also be a bus issue. Try disconnecting the battery for 15 minutes to reset the car's electronics.
battery, clicking, e46, lights flashing, won't start
