DIY: **The New Unofficial Auto ----> 5 speed swap** Lots of pictures!!! - Page 23 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 488 votes, 4.98 average. Display Modes
Old 02-14-2017, 07:51 AM   #441
HudsonMotorsports
My Ride: 330ci
I'm doing the 5 speed swap right now on my '01 330ci and wanted to know if I need a new brake reservoir that the clutch would now tie into or if I can alter the original reservoir from the automatic set up?
HudsonMotorsports is offline   Reply With Quote
Old 02-14-2017, 07:53 AM   #442
orb
My Ride: 325Ci
There's a nipple on the current one that you cut and feed the line into.
orb is offline   Reply With Quote
Old 02-14-2017, 10:44 AM   #443
HudsonMotorsports
My Ride: 330ci
Thanks! I don't know how I missed it!
Old 02-19-2017, 10:44 AM   #444
HudsonMotorsports
My Ride: 330ci
Ok, next question on doing the clutch line on the swap. Do I need to remove the gas peddle in order to route the steel line that goes from the clutch master cylinder to the flexible line that connects to the clutch slave cylinder line.
Old 02-19-2017, 11:30 AM   #445
chanman1029
My Ride: 2003 325i
Just pull the carpet back as far as possible, i had trouble getting that line to fit properly but I promise it works. A tip is to screw into into the master cylinder, and then mount the master cylinder. Just make sure the when pulling the line through that its all the way through before you mount it so you dont bend it.
2003 325i Auto ---> 5-speed
chanman1029 is offline   Reply With Quote
Old 02-23-2017, 10:32 PM   #446
HudsonMotorsports
My Ride: 330ci
Hey Chanman, thank you for the advice....do I need to pull out the gas peddle to get the carpet out and if so.....how do I get the gas peddle out
Old 03-04-2017, 10:09 AM   #447
canosoto86
My Ride: 2001 BMW 330I
I have a question, am doing a 5spd swap on my 330i within a week from now, I have most parts already, but I want to ask.
Is the guibo for the 330i same manual to auto? Reason for asking is RealOem only show one (96mm) and even in autoparts all I see is the (96mm), now I know the 330 came both manua and auto, so am assuming at this point they use the same. Am I correct?
canosoto86 is offline   Reply With Quote
Old 03-04-2017, 10:54 AM   #448
chanman1029
My Ride: 2003 325i
Sorry for responding so late, but if I remember right i did not remove the gas pedal. I removed the trim piece that is on the floor, which the door closes onto. Then pulled it back from that point as far as i could
Old 03-04-2017, 12:36 PM   #449
HudsonMotorsports
My Ride: 330ci
Thanks a ton! I'm hopefully finishing up the swap today!
Old 03-04-2017, 03:33 PM   #450
chanman1029
My Ride: 2003 325i
What do you have left?
Old 03-04-2017, 05:40 PM   #451
HudsonMotorsports
My Ride: 330ci
I still have to install the drive shaft, connect the rad and wiring then install the front end....not a ton really.
Old 03-09-2017, 08:48 PM   #452
HudsonMotorsports
My Ride: 330ci
clutch switch wiring
Originally Posted by Turpe View Post
Just finished the swap on my '01 330ci vert. Thanks for the info! All to do now is code.
A few things I did different.
1. I only used the master cylinder clutch switch. I wired it up as posted and everything works as it should. Cruise, start and both brake and clutch stop the cruise.
2. Reverse light connection.
I ran a wire from the switch on the tranny to ground. (Does not matter which one) and the other to the DME box under the hood. In the box toward the front of the car is the reverse light relay. It's blue. If you take the relay out and disconnect the plug you can see it has 4 wires connecting to it. The wire you need is the brown/black one. I cut it and connect the other wire from the tranny switch to it. So when you shift into reverse it completes the circuit by connecting the relay switch to ground. Just like the automatic transmission unit did. My reverse lights and also my back up sensors work like they should.
The only thing not working is the mirror tilt in reverse. Which I never liked anyway.
Hi, when you say that you "wired it up as posted" can you send me the post that gives you the directions on how to wire it up?
Old 03-11-2017, 06:02 PM   #453
chanman1029
My Ride: 2003 325i
Check step 9, go with the clutch switch module one. I do not have the 3 pin switch in mine. It mounts on the side of the master cylinder and it tells you where to put each wire. Also check out the diy write up from ivegotissues666. His 6-speed swap is wired the same way
Old 03-18-2017, 09:53 PM   #454
chanman1029
My Ride: 2003 325i
Hello, so about a year ago I did this swap and just bridged my auto wiring harness to get the car to start, i dont care about the lights on the dash so I never recoded it. But I'm going to buy the active autowerke tune for it with headers and was wondering if the tune would conflict with it not being recorded. Does the engine run differently when its coded to a manual? I'm confident i can code it myself, its just all the instructions online are sort of confusing and hard to follow.
http://m.ebay.com/itm/262799579850?_mwBanner=1
Will this work for recoding it to a manual? I'm probably going to buy a Simon 3 cable to apply the tune myself and didnt know if i could do it with that or if i have to have a GT1. Any advice would be greatly appreciated, thank you.
Chandler
Old 06-15-2017, 08:20 AM   #455
spinelli006
My Ride: 2001 bmw 330ci. 1997
awesome write up , so i bought a E46 with the manual conversion recently and not sure if the car had everything done correctly i mainly wanted to know will the car run and drive without the ecm being reflashed
spinelli006 is offline   Reply With Quote
Old 06-15-2017, 10:56 PM   #456
chanman1029
My Ride: 2003 325i
Ive been driving mine for over a year without a reflash, you will be fine.
Old 06-20-2017, 11:48 AM   #457
JiXer
My Ride: BMWs
SA Coding
So, I am trying to figure out exactly how to use SSS to recode for this swap.
2001 330ci with MS43
I have been searching around in this thread, but aside from the original post (which isn't complete in regards to the SA code), I can't really find a detailed set of instructions. Is it in this thread somewhere?
Can we start a separate thread?
Should I just try using NCS? Will an INPA cable work for that?
edit: I don't have a windows machine capable of running NCS :/
JiXer is offline   Reply With Quote
Old 07-03-2017, 10:51 AM   #458
armenh7
My Ride: 2002 325i
Are you sure about that???
http://forum.e46fanatics.com/showthread.php?t=1126314
armenh7 is offline   Reply With Quote
Old 07-03-2017, 10:52 AM   #459
armenh7
My Ride: 2002 325i
Hey neil your pictures need to be updated!
Old 07-08-2017, 07:33 PM   #460
spinelli006
I picked up 2001 330ci with the manual swap the speedo doesn't work any ideas where the speed sensor should be wired to
Sent from my SM-G930V using Tapatalk
conversion, evo3, manual, swap, uuc
