Sponsored by BAVSOUND
Old 09-02-2009, 03:46 PM   #1
neil1138
Exclamation That's it, I'm done. DICE Silverline = fail. K-Bus error
Let me start out by saying that I have had continuous errors with my DICE Silverline unit. (I have a 2003 business radio btw) I've exchanged/done warranty returns on the DICE to no avail. I've just been living with the errors that it has. For example, it sometimes doesnt recognize that it has an ipod plugged in and it gets stuck at ATTACHED. Also, I lose text display all the time and have to reset the DICE unit. That aside, now the problem.
The issues I had when I turned my car on:
1. turn signals dont light up inside but do work outside. (green blinker on cluster doesnt work)
2. seat belt light would not go off before and now its just off regardless if i am buckled or not.
3. sunroof switch intermitently doesnt work and does work.
4. wipers intermitnently work and dont work.
5. steering wheel controls dont work
6. open door sensors dont work at all.
7. A/C doesnt work at all.
When I noticed that the turn signal indicators and A/C didnt work, I knew exactly where the problem was originating at. But lets talk some more.
Lets pose a situation: I get in my car and start the car with the drivers door open and my seatbelt not buckled. These are the two warning light that come up on my cluster. Normal right? But when I closed the door, the light didnt go away... And when i buckled my seatbelt, the light didnt go away. Weird huh? It seems like the cluster lights that were on during startup stay there until the ignition cycled and no other lights would come on. For example my high beam indicator light wouldnt show up on the cluster even though they were working. Anyway...
I thought about it for a second and realized that it had something to do with the K-Bus because it was the link between all of those modules. I wondered why one of the modules went bad all of a sudden then I realized there was no way it could have, I havent messed with anything electrical except the DICE unit... well I unplugged it completely and disconnected my battery for 2 hours. I really dont want to have to mess with digging into the glove box and disconnecting wires from the K-Bus connector. Well I came back after two hours and plugged the battery back in, everything was purdy!
Just to make sure, I disconnected the battery and connected the DICE again, did a couple of ignition cycles and sure enough, problems arose again. I think the K-Bus wasnt getting 12v or whatever from the radio interface messing up.
I dunno, I'm just done with the DICE unit, I'll just make CD's until I figure out what to do with the DICE. Burn it or run it over, I dunno yet.
Just for the record, my car is functioning 100% since the manual swap coding, no cluster errors or anything. Everything was completely functional after I did the coding, I checked with the GT1. No stored errors or anything, all the modules were performing perfectly. And this was before I even got a DICE.
I figured this belonged in General because it dealt with the K-Bus and general body electronics, DICE aside. Cheers guys, I figured I needed to tell somebody. Someone might be having a similar problem
neil1138 is offline   Reply With Quote
Old 09-02-2009, 03:57 PM   #2
CoconutPete
My Ride: E90 330i
Dang!
Sorry it didn't work out for you. Weird how it just doesn't work for some people. Mine's a bit flaky at times but works pretty well.
The word "there" can appear as a pronoun, as in “over there."
"Their" is a possessive pronoun. In a phrase like “Susan and Bill's car,” it could be used to to make a new phrase: “their car.”
”They're” is a contraction of “they are.” “They are” should always be able to replace “they're.”
Extra Credit: It's "I'm looking for an M3"
not "I'm looking for a M3".
CoconutPete is offline   Reply With Quote
Old 09-02-2009, 03:59 PM   #3
neil1138
Yeah I just haven't had a good experience with it, no worries. We all know that generally, everyone loves their DICE unit. Sometimes it just doesnt work and this was just one of those cases. My car is allergic to the DICE unit
Old 09-02-2009, 04:05 PM   #4
Slvr330zhp
My Ride: 2003 330iZHP
Dang! I hope I don't get those problems when I install mine.
Slvr330zhp is offline   Reply With Quote
Old 09-02-2009, 04:32 PM   #5
MojoJoe
My Ride: leaks fluids
Sounds exactly like the problem I have had with a GROM USB interface. When connected it pulled the bus voltage down to 6v, causing chaos with the AC and sunroof. The replacement arrived today so when I get my car back from the shop on friday I will hook it up and hope it plays nicely with the car's electric bits.
Probably (in both cases) caused by a faulty serial interface.
MojoJoe is offline   Reply With Quote
Old 09-02-2009, 06:20 PM   #6
tom @ eas
european auto source
tom @ eas's Avatar
My Ride: e92 S/C M3
DICE doesn't touch kbus, it uses ibus.
Were you the original owner of the kit? If so - can you please read off the numbers from the bottom of the module beneath the barcode for me? Also, what coding was being performed and why?
tom @ eas is offline   Reply With Quote
Old 09-02-2009, 07:41 PM   #7
Megalocnus
My Ride: 05 330i ZHP/MT
Neil, which DICE interface have you used - the one that connects with the headunit or the one that goes to the CD changer port in the trunk?
Megalocnus is offline   Reply With Quote
Old 09-02-2009, 07:45 PM   #8
neil1138
Radio interface. I'm the original owner of the Dice, it's the newest version as of a month ago because I had it warranty exchanged by dice for other problems. I did coding for my manual swap, pin that on me. Please try
I'll get you the number in a min, I'm away from my car
Old 09-02-2009, 07:50 PM   #9
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
I would recommend contacting DICE to speak directly with a technician on your issue. DICE can be contacted at 888.342.3999 or by email at support@diceelectronics.com.
Old 09-02-2009, 08:26 PM   #10
neil1138
The radio DEF is one of the modules that connects to the K-Bus, unless I'm completely mistaken... and I have the radio interface... Not the trunk interface.
Here is the number you asked for: A00127 - 0609
No offense, and I mean NO offense to you or anybody, but the techs at DICE know nothing more than to replace DICE units in conditions like this. How many times am I going to have to replace this electronic I paid good money for? I've only heard that DICE is the absolute best iPod integration for BMWs but I havent witnessed these claims once. I've only had problems, how many times am I going to be inconvenienced?
Old 09-02-2009, 09:27 PM   #11
sna77
sna77's Avatar
My Ride: BMW
where did you hear such a thing?!
sna77 is offline   Reply With Quote
Old 09-02-2009, 09:32 PM   #12
neil1138
I was trying to be nice to Tom, trying... I'm holding in the anger as best I can.
Old 09-02-2009, 09:40 PM   #13
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Please contact DICE directly - I've already informed them of the issue and they are expecting your call.
Old 09-02-2009, 09:45 PM   #14
neil1138
Oh, well thank you very much. I hope the 3rd DICE is the charm! Because I've already replaced my headunit once. All for the sake of proper ipod integration. I've covered all grounds, the DICE is the broken link.
Old 09-02-2009, 09:49 PM   #15
chicane
Banned
My Ride: BMW M3
Thumbs down
I thought I was the only one. I bought two of these Dice Silverline's from EAS and these things are flaky as h3ll. I frequently have problems with the DICE not recognizing my iPhone or not displaying the correct song info and my only recourse its to unplug the battery....DICE Silverline = fail.
chicane is offline   Reply With Quote
Old 09-02-2009, 09:51 PM   #16
k41
My Ride: 04 330CI TiAG
Did you plug urs to the cd changer in the trunk or radio interface in fhr front?
wow i was about to jump on the dice until i read this... =\
k41 is offline   Reply With Quote
Old 09-02-2009, 10:25 PM   #17
zhp pilot
Falling from 14k ft.
zhp pilot's Avatar
My Ride: is totaled :(
Wow, I've never heard of problems like this with the DICE. Mine occasional gets stuck on ATTACHED. I leave it plugged in almost all the time and it stays on. When it gets stuck, I just unplug it and plug it back in. No big deal really but I have a spec.dock on the way so I shouldn't have this problem anymore as I will be unplugging it every time I get of out the car. Hope you get things figured out.
'04 Silbergrau Metallic ZHP 6MT
zhp pilot is offline   Reply With Quote
Old 09-02-2009, 10:52 PM   #18
neil1138
Yeah we'll see. I'm not one to keep installing failed products on my car, just to make my car keep malfunctioning. We will see. What I don't want is just another DICE unit sent my way as some sort of retribution. I'm tired of dealing with these kind of problems
Old 09-02-2009, 11:00 PM   #19
sna77
sna77's Avatar
My Ride: BMW
Have you missed the 2k post thread about the Dice ? ha
Old 09-02-2009, 11:02 PM   #20
Chris-TK
My Ride: Mk VI GTI
USA Spec > Dice
K.
Chris-TK is offline   Reply With Quote
cluster, dice, dme, error
