Sponsored by BAVSOUND
Old 09-04-2009, 09:05 PM   #41
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
oem ipod kit ftw?
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 09-04-2009, 10:06 PM   #42
neil1138
Originally Posted by jbeurotech View Post
You relieze I-bus and K-bus a pretty much the same thing depending on what car you are talking about???
BTW the E46 does NOT have an I-bus only a K-bus and yes the Dice goes into the K-bus.
I had a Dice last week we tried to install kill the K-bus on an E46 turns out the harness they supplied was defective. I repinned their harness and it was fixed.
werd. Thanks Seth. I did my homework before I went out and trashed on the Dice kit. I'm guessing he assumed I had the trunk interface but either way, its still messed up. The radio interface of the Dice uses the radio harness, therefore it uses the K-Bus. Someway somehow, the Dice module/harness is causing the K-Bus to not get 12v so it freaked out.
I kinda just laughed off Tom's comment.... sorry but it's true. He was very quick to slander.
Originally Posted by 330ciandr6 View Post
oem ipod kit ftw?
Yes Drew... If the new kit they are sending me doesnt work, I will be dumping the Dice/preaching about it's demise.
neil1138 is offline   Reply With Quote
Old 09-05-2009, 12:31 AM   #43
ZZen330
My Ride: 2002 330Ci
Originally Posted by Paco II View Post
Not all of us here are missing the boat I too use the Dension Gateway 300, and it is fantastic. Far superior and much more stable than the DICE units. No silly DIP switches to mess with. Rock solid. Fantastic feature set. Costs a bit more than the DICE, but worth every darn cent. It just works.
It's actually really unfortunate that Dension left the US market. People here in the US are so missing out on the best iPod connection kit for the E46 + Business CD radio.
P.S. I couldn't imagine what I would do without the ABC-Search feature!
Does text id scroll on the display?
Also, how do you change modes from ipod to aux/3.5mm to USB and back?
Thanks.
ZZen330 is offline   Reply With Quote
Old 09-05-2009, 08:30 AM   #44
sna77
sna77's Avatar
My Ride: BMW
Neil, when you had the trunk kit with the Dice, did you ever try swapping pins 2&3 on the k-bus wires in the trunk? The Dice has the ground on the wrong pin.
sna77 is offline   Reply With Quote
Old 09-05-2009, 11:47 AM   #45
neil1138
I've never had the trunk interface yet, the Dice person said they would send me both interface harnesses but I have the radio interface as of now.
Old 09-05-2009, 03:25 PM   #46
chicane
Banned
My Ride: BMW M3
I didn't have any better luck with the trunk interface.
chicane is offline   Reply With Quote
Old 09-05-2009, 03:35 PM   #47
neil1138
Yeah I'm hoping that isnt the case with me, but if it is... well i'll be pissed
Old 09-05-2009, 07:09 PM   #48
Megalocnus
My Ride: 05 330i ZHP/MT
Can the problem be not with the DICE unit, but with the headunit connector, like some pins breaking contact occasionaly? No way to be sure about it, but since you have already tried two units with same result...
I agree the DICE is far from perfect (does not bookmark playlists, does not remember the shuffle setting, etc.), but it has been working fine for me. I used the trunk interface (read the manufacturer's warning the unit should be made easily accessible) and have experienced two problems:
- the text stops scrolling until the unit is reset. However, I rather like that it is not moving and keep it this way. :-) I guess this is because I have an early CD43 headunit.
- occasionally the DICE unit will switch the ipod to "repeat one" mode. However, this causes the first song to be repeated endlessly, not just once. Very annoying sicne the only way to turn the repeat mode OFF is to disconnect the ipod and do that manually. Others reported the same problem here and we got the advise to disconnect the player whenever the car is parked. Would have been an easy solution, but I'm using the ipod only for playing music in the car (and only when I'm not listening to radio), so for now I just keep turning the repeat setting OFF whenever necessary.
In other words, only minor problems, restricted to mp3 playing. No messing with car's other systems at all.
Megalocnus is offline   Reply With Quote
Old 09-06-2009, 06:23 PM   #49
champ222
My Ride: 330CI
Thanks.
On the Dension, you tap cd 6, then it will display >Source or something, then you press > either on the stereo or the wheel to select IPOD, USB or Aux, then you hold > to make the selection.
champ222 is offline   Reply With Quote
Old 09-06-2009, 06:24 PM   #50
champ222
My Ride: 330CI
Glad your enjoying it too
Old 09-06-2009, 06:33 PM   #51
Owtlaw333
My Ride: 2009 Mazdaspeed 3 GT
The DICE uses the exact same feature. I have a pre-Silverline unit though and have no clue how the Silverline works.
Bringing it back for the new people...
productionof1.com
|||_Buy my photos?_|||
Owtlaw333 is offline   Reply With Quote
Old 09-07-2009, 12:39 PM   #52
Paco II
My Ride: 2005 325i
The way to do it on the Dension Gateway is simpler and much more intuitive than on the DICE units. Also, the DICE unit's don't have USB But the underlying point is that if the OP is 'done' with the DICE and is looking for a great/better alternative, he should definitely check out the Dension Gateway 300.
Paco II is offline   Reply With Quote
Old 09-07-2009, 12:52 PM   #53
Owtlaw333
I just told you it's the exact same way, how is it simpler?
But yes, point taken.
productionof1.com
|||_Buy my photos?_|||
Old 09-07-2009, 01:42 PM   #54
Paco II
My Ride: 2005 325i
It's been a while, but I thought with the DICE it was something like you hit Disc 5, then track 1 or 2 switched between inputs. But I don't remember there being any nice labeling or anything to make it clear which input you had selected. But I could be remembering incorrectly.
With the Dension Gateway, there is no guessing what you need to do: you hit Disc 6, which takes you into the menu. The first menu option is called "Sources", and that shows in the display. Selecting that, you can then scroll through a list of all the inputs, and it will show their names as you scroll through. So it is very clear and obvious which input your are selecting. That's why I said it was more intuitive.
Old 09-07-2009, 02:37 PM   #55
Owtlaw333
Yeah, you hit 5 and switch and it says on the screen "Aux" or "IPod" depending which is selected. So they are essentially identical in that aspect.
productionof1.com
|||_Buy my photos?_|||
Old 09-07-2009, 11:06 PM   #56
neil1138
I will def look into it if the new DICE module I'm getting continues to fail
Old 09-08-2009, 07:59 AM   #57
r6vr6
My Ride: 2002 ///M3
I have had issues with DICE as well. The radio connected unit in my wife's x3 won't wake up unless you start the car turn it off and then start it again. I tried everything multiple units blah blah blah. I ended up keeping the last unit and use it on long drives only.
r6vr6 is offline   Reply With Quote
Old 09-09-2009, 04:10 PM   #58
neil1138
Just received the new DICE unit and harnesses in the mail today, will install soon and post back with results. Just want to say thanks to DICE for the quick shipping, I'm impressed
Old 09-10-2009, 02:29 AM   #59
pastE36prsntE46
My Ride: HPF STG 3; 95 FI M3
Tom @ eas slandering, no way I dont believe it. That has never happened before......wait oh yes it has. I would avoid DICE like the plague and rather spend my money on cds.........
pastE36prsntE46 is offline   Reply With Quote
Old 09-10-2009, 10:26 AM   #60
apollotrance1
My Ride: '02 330i, '05 GSXR1k
having CD's and CD books in the car sucks, as well as the DICE, apparently. If he has an older headunit model, which cant adapt to the regular AUX imput, what would be the best way to go??
And goodluck with the new unit, hopefully it works
apollotrance1 is offline   Reply With Quote
cluster, dice, dme, error
