Thread Tools Search this Thread Rating: Thread Rating: 75 votes, 4.95 average. Display Modes
Old 02-15-2017, 12:22 PM   #601
GCoop
My Ride: '04 325xi
Originally Posted by BaliDawg View Post
For those reading, note that the H8 is a lot cheaper, fits perfect, and has a higher CCA.
https://www.walmart.com/ip/Everstart...49-EP/49988398
That's not an AGM.
GCoop is offline   Reply With Quote
Old 02-15-2017, 02:01 PM   #602
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Originally Posted by GCoop View Post
That's not an AGM.
Correct. But that's not required for an E46.
///Mmmmmm...
Old 02-15-2017, 05:35 PM   #603
Swiff
My Ride: 2002 330xi
Just Put A bosch 49-D battery in my car. Came out of a Mercedes-Benz. Just had to remove the stopper tab in the battery tray and all is good again.
Swiff is offline   Reply With Quote
Old 02-15-2017, 05:39 PM   #604
GCoop
My Ride: '04 325xi
Understood but neither is the 900CCAs its like comparing apples and oranges or Mazdas to BMWs.
The price you linked for the lead-acid is average at best for an economy battery. Considering one can get an Interstate, Exide, or Bosch LA for just a few dollars more when shopping wisely.
To each their own though. I will concede that the Walmart battery will work just fine. I'm actually still on my initial replacement that I got from there almost 7 years ago now. However, that was back when Exide was the supplier for the EverStart Maxx line. I probably will go with something else next go around which is probably pretty close at hand.
Old 02-19-2017, 02:31 PM   #605
Miko_10
My Ride: 330i 5 Spd
Originally Posted by jmo69 View Post
I'd be concerned about hydrogen collecting in your trunk, remember the Hindenburg.
great..where would the vent hole be?
FS(PM me if interested, MID Atlantic Area, 22307 zip)
- 2 M68 fronts w/ winter tires, local pick up preferred,
- OEM Pre face Sedan Clears.
Miko_10 is offline   Reply With Quote
Old 02-19-2017, 03:30 PM   #606
bimmernate
My Ride: 2003 330i ZHP
Originally Posted by lllRazorlll View Post
Should the voltage still read 12.4v when key is in position 2 after sitting overnight?
Actually I take this back. I just checked it. It's 12.6V exactly with the car off, 14.2V when the car is on. That being said, I have driven the car today.
I measured 12.4V at the fuse box when i was doing another project.
2003 330i ZHP 6MT
Performance: Koni Sport Struts/Shocks, Eibach Pro-Kit, 17x9 Apex ARC-8, TMS F&R Sway bars, M3 RTABs w/ Vorshlag Limiters, M3 Strut Brace
Aesthetics/Functionality: TFX Projector retrofit by lightwerkz, 20% Tint, OEM Aux Input, Clear corners, LED taillights, M3 Steering wheel, Black kidney grills, mobius dash cam
bimmernate is offline   Reply With Quote
Old 02-19-2017, 04:32 PM   #607
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
On the right side of the battery near the positive terminal
Thanks for double checking
>IN SEARCH OF GRAY SEDAN SPORT SEATS<
lllRazorlll is offline   Reply With Quote
Old 03-14-2017, 09:57 AM   #608
Kpriest
My Ride: 2005 325i
I recently was doing an inspection of my 05 325i during an oil change and noticed my battery has a production sticker of 10/2009.
I checked the voltage both running and off. Registered 14.1V and 12.5V accordingly. Never have had any issues starting.
My question is, what is the longest life you have gotten out of your battery? I currently have a Duralast 94R.
Kpriest is offline   Reply With Quote
49-dl, advanced, agm, auto, autozone, battery, duralast, h7, h8, official, pepboys, thread, walmart
