///M3 Forum
Thread Tools Search this Thread Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Old 05-25-2015, 05:56 AM   #21
Tiago
My Ride: M3 e46
Nice diy. Very well detailed.
My car only shifts R, N and 2nd. This happened after hitting a road pothole. It already happened before and came back to normal after sitting in the garage for some weeks or after hitting another road bump or pothole. This lead me to think to be more related with a electrical issue than mechanical but my local dealer wants to replace the whole gearbox. By your experience, can you give me some directions to start looking for the real cause of it?
Btw, in 4 year i already replaced the hidraulic pump due to overheating symptoms that lead to gear poping out to neutral for +10sec, and 2 years later with the hpf clutch installation, the replacement of the gps and the compression springs as a preventive maintainance.
ESS VT2-575 / AEM WMI / Supersprint Race System / 3.91 Diff / Stoptech ST60 and ST40 / Bilstein PSS9 / UUC Sways
CLICK HERE FOR PICS OF MY CAR
Tiago is offline   Reply With Quote
Old 07-03-2015, 10:59 AM   #22
///M3Rivera
Originally Posted by roadtrip1098 View Post
Glad you guys like it... Hopefully it will save some of you some cash. Also did a Water pump DIY, but there seem to be plenty of people out there that are capable of doing that. As for SMG stuff, if you ever have an issue with yours, PM me I read the hundred and some odd page technical manual from BMW on it and have a pretty good handle on troubleshooting them.
i have th selection angle and the shift travel codes , do u think is my gear position sensor ?
///M3Rivera is offline   Reply With Quote
Old 04-10-2016, 11:37 AM   #23
snyderdb
My Ride: BMW 330ci
Hello Road Trip
Hello Road Trip...
I came across your DIY when I searched using this query "4EF6/E1 - Sensor clutch position".
My 2004 BMW 330Ci (SMG) has been in safe model for several weeks and I do not know the cause.
I did recently replace the alternator and the battery is new.
I have attached an output log from a BMW Scanner (v 1.4.0).
I am wondering if replacing this switch might possible fix my safe mode issue.
Any thoughts/guidance/suggestions would be tremendously appreciated!
Thank you Road Trip!
VR,
Dave
snyderdb is offline   Reply With Quote
diy, gear, position, replacement, sensor
