Old 03-10-2013, 04:00 PM   #1
Mau330i
My Ride: '02 330i
Question Wahler Thermostat Leak
Hello,
This is the second Wahler thermostat that develops a leak in 6 months!!!!
The leak comes from the o-ring that "seals" the electrical component of the thermostat and is the second thermostat that fails like this.
I replaced the original at the same time that all the other parts of the cooling system and it failed 2 months after so I bought a new one (same brand) and this week I noticed the same leak as in the previous unit.
I did disassembled the first one and the result is in the attached photo.
Should I replace the o-rings??
Should I replace the full unit AGAIN??
Is this a common problem with Wahler thermostats??
Is there any way to test the electrical component?? (I'm thinking on installing the original again by now if it is ok)
Some extra information:
Cooling system has been renewed (completely)
Bleeded correctly and extra coolant removed form ET before starting
Coolant level ok before leak
Coolant operation temperature from 203F to 210F
Mechanical fan deleted and using the electrical from a manual
Any help or advice will be really appreciated.
Mau330i is offline   Reply With Quote
Old 03-10-2013, 04:52 PM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I'd be either suspicious of your source or wonder if you didn't clean where it mounts well enough. If it was the same source, I'd go to the dealer or someplace different next time. Just saying.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 03-10-2013, 04:54 PM   #3
eclipsor
My Ride: stahlblau
Send a message via AIM to eclipsor
Crap, I just bought one
Jet Black 1994 325is -> Steelblue 2003 325i
eclipsor is offline   Reply With Quote
Old 03-10-2013, 05:25 PM   #4
Optio
My Ride: 328i
I suspect your problem is the cylinder head of the mate. My Whaler stat has never leaked.
Optio is offline   Reply With Quote
Old 03-10-2013, 06:11 PM   #5
Zell
Zell's Avatar
My Ride: so turbo wow
Does it seem to leak directly at the electrical connection? If so, I've heard of that happening on a few different occasions here. Go with Behr.
Old 03-10-2013, 06:12 PM   #6
lcoleman
My Ride: '79 Massey Ferguson
i'd be either suspicious of your source
+1
Old 03-10-2013, 10:33 PM   #7
Mau330i
My Ride: '02 330i
Yes, it is leaking from the connector... Do you think I should replace the o-ring?????
Old 03-10-2013, 10:38 PM   #8
Zell
Zell's Avatar
You could and see if that fixes it, but I'd personally get a Behr which doesn't seem to have that problem. Slightly different electrical connector design.
Wahler:
Behr:
I have no idea if the connector design difference is the actual reason for the leak, but I haven't heard of this leak happening with Behr thermostats.
Old 03-11-2013, 12:08 AM   #9
My Ride: Lexus
I've never heard of the electrical connector having its own seal. any closeups? if you are certain its leaking there, then I just say buy a thermostat from the dealer and be done w/ it.
i have a Wahler and it's been perfect. would buy again
Old 03-11-2013, 01:27 AM   #10
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Just return it to where you bought it and have them give you a replacement.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 03-11-2013, 04:18 AM   #11
SDpnoy
My Ride: 330Ci and M3
Where did you buy it from?
I did a cooling system overhaul and bought parts(non-OEM) from ECS Tuning and a couple of them leaked. Troubleshot and put back my original parts and no leaks.
I returned the parts and bought OEM BMW from the dealer. No leaks.
SDpnoy is offline   Reply With Quote
Old 03-11-2013, 04:31 AM   #12
Megalocnus
My Ride: 05 330i ZHP/MT
I'm on my third Whaler thermostat - all of them purchased from BMW dealers - one eventually failed to maintain the operating temp above 90 C, but none of them had any leaks.
Megalocnus is offline   Reply With Quote
Old 03-11-2013, 05:21 AM   #13
PerfectStorm01
My Ride: 320Ci
My wahler leaked after 2 or 3 months so I had it replaced with a behr. Haven't had a single problem since.
PerfectStorm01 is offline   Reply With Quote
Old 03-11-2013, 08:40 AM   #14
Redryan98
My Ride: 07 Legacy GT 5MT
I've heard there's been issues on the Wahler. Unfortunately I did not come across the info until just after I installed one. So far so good (only been a couple weeks) but if it does leak I'll be replacing with a Behr.
Redryan98 is offline   Reply With Quote
Old 03-11-2013, 11:17 AM   #15
Kubica
My Ride: 2003 325xi
OP- I had the same exact issue with my Wahler thermostat after 10k miles. I replaced with OE and no more leaks.
Old 03-30-2013, 06:29 PM   #16
Mau330i
My Ride: '02 330i
Wahler Thermostat O-Ring
Today I removed the 3 months old Thermostat and reinstalled the previous one (also a Wahler) but with a new / thicker o-ring.
After analyse this part and because if this leak again it can be detected with no risk to the car I decided to change the original o-ring with an "improved" one to see if this fixes what I think is a design problem. If it doesn't I will use a new Behr thermostat.
Attached some pictures of the disassembled thermostat I just removed so you can see the o-ring I change and let me know what do you think about this.
Lets see if this works....
ID:	497917   Click image for larger version
Old 03-30-2013, 06:42 PM   #17
e46alfonso
My Ride: 330xi MT, mustang gt
I bought a genuine stat from the dealer a year ago and it's been leaking, not sure for how long. I'm just going to live with it. What a waste of $110.
Old 03-30-2013, 08:03 PM   #18
pawelgawel
My Ride: 330CI
^ BMW gives 2 year warranty on parts... get an exchange
pawelgawel is offline   Reply With Quote
Old 04-18-2013, 11:23 AM   #19
RMAAS
My Ride: 04 325 CiC 87 K75C
Maui330i:
Can you give some details (PN, Dimensions) on the replacement O-ring you used ? Did it work?
RMAAS is offline   Reply With Quote
Old 04-18-2013, 11:33 AM   #20
BMWCaptain
Maui330I
How did you go about removing the part to replace that o-ring?
BMWCaptainE46.com
leak, thermostat, wahler
