Wahler Thermostat Leak - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-18-2013, 11:47 AM   #21
My Ride: Lexus
That seal area looks dirty. Try cleaning it and reinstalling
Old 04-18-2013, 05:01 PM   #22
yurekk
My Ride: 2003 325i
My Wahler unit also developed a leak from the o-ring after roughly 15k miles. I replaced it with Behr. So far so good.
yurekk is offline   Reply With Quote
Old 04-18-2013, 05:10 PM   #23
My Ride: Lexus
FWIW, my Wahler has been going strong for 3 years/40k so far
Old 04-18-2013, 05:33 PM   #24
tock172
My Ride: '12 135i Dinan S2
I installed my Wahler thermostat in January and 3 months later it's fine. Absolutely no issues. I just installed a Wahler thermostat on an '02 330ci yesterday for a friend. The original thermostat on his car was manufactured by Wahler and had a BMW stamp. Wahler is the original equipment manufacturer.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 04-18-2013, 06:13 PM   #25
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Never had a leak from the many Wahlers I have installed.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptain
BMWCaptain is offline   Reply With Quote
Old 04-18-2013, 07:20 PM   #26
dznuts007
My Ride: 2001 325i Sedan
Originally Posted by BMWCaptain View Post
Maui330I
How did you go about removing the part to replace that o-ring?
Get a fine pick. Right behind the plug, you'll notice a little "latch". Put the pick behind the latch (you're not gonna have any space in front of the latch) and gently pull it up and then twist the plug forward then pull out. I think you have to remove the thermostat from the housing before that plug housing will come out though
dznuts007 is offline   Reply With Quote
Old 04-18-2013, 07:37 PM   #27
Mau330i
My Ride: '02 330i
Don't waste your time with the o-ring... it didn't work. at least not for me. I'm going to replace it with a behr unit.
Maybe this problem is limited to a certain manufacture date or defective production lot.
I have just checked and both thermostats were manufactured on Jul/2011
If some of you who had problems with this thermostats still have them maybe you should check the manufacture date and see if it is the same or close to 07/2011
Mau330i is offline   Reply With Quote
Old 04-18-2013, 08:04 PM   #28
dznuts007
Totally possible. Good that you noted the dates on both of them. Have you tried contacting Wahler to see if they knots of any issues with that lot#? Maybe the dealership might have some info too
Also, did you follow the torque specs when tightening the bolts? I ended up cracking one thermostat housing due to a faulty torque wrench. Also you might crush the gasket of you over tighten it. Too loose and it might leak
Old 04-18-2013, 08:20 PM   #29
Sweetness
My Ride: '01 325i
Wahler for almost 20k and no problems so far.
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 04-18-2013, 09:37 PM   #30
Mau330i
My Ride: '02 330i
I have contacted Wahler... lets wait for their answer. Anyway I'm going to install a Behr unit next week.
I did follow torque specs.
Old 04-18-2013, 09:55 PM   #31
dznuts007
Oh yeah and did you tighten the bolts in the proper order? Not sure if it'll make a difference but always good to follow good practices
Old 04-19-2013, 07:53 AM   #32
Mau330i
My Ride: '02 330i
nop, no particular order.... just 10Nm for the 10mm and 20Nm for the 13mm.
I didn't know of a particular order, but if there is one I'm sure Mango will came in with it.
Old 04-19-2013, 08:55 AM   #33
dznuts007
I would have done it in a criss-cross pattern
Old 04-19-2013, 10:34 AM   #34
BimmersGarage
My Ride: E46 330i
I have a Behr thermo. & it's held solid for 48k+ miles so far. I personally prefer the design of the Behr - where there's a big metal C-clip holding down the heater element vs just a tiny plastic latch.
And, as long as you followed the torque specs you should be good to go because all you're doing is seating the rubber gasket - the heat from the aluminum block does the rest (of sealing against the unit) once the motor reaches operating temperatures.
BimmersGarage is offline   Reply With Quote
Old 04-19-2013, 12:31 PM   #35
RMAAS
My Ride: 04 325 CiC 87 K75C
I just replaced my Wahler with a Behr. The Wahler was leaking from the o-ring like the one shown in Mau330i's pictures. My Wahler's production date was 06 2011.
RMAAS is offline   Reply With Quote
Old 04-19-2013, 04:40 PM   #36
Megalocnus
My Ride: 05 330i ZHP/MT
It seems the OE Whaler thermostats sold by BMW dealers don't leak, while those by other vendors do.
Megalocnus is offline   Reply With Quote
Old 04-19-2013, 04:41 PM   #37
My Ride: Lexus
I've installed at least a dozen vendor-sourced OEM Wahlers with a 100% success rate.
Old 04-19-2013, 05:01 PM   #38
Megalocnus
Wow, you must be very popular :-)
I have installed only four, three of them on my car, all of them made by Whaler (purchased from BMW dealers or Pelikan parts). Had a couple of soft failures jfoj has a thread on, but no leaks.
Still, it seems that there must be a bad batch of OEM Whaler thermostats, otherwise there wouldn't be so many people complaining theirs are leaking at the electric connectors. None of the OE Whalers seems to have this problem, so I assume this batch didn't make its way to the BMW dealers.
So far I've seen only one report of a Behr thermostat having the same problem.
Old 08-06-2013, 02:20 PM   #39
tcphoto
My Ride: E92 335 MT Coupe
I installed my Wahler thermostat back in January and a month later I had a very slow leak. The coolant was coming from the bottom between the two bolts. After double checking the torque and adding a little coolant every week or so, I simply called ECS and they are sending a replacement. He said that they aren't having problems with them but we'll see how this one does. I cleaned the area well and torqued the 10mm bolts to 10mn and the 13mm to 20mn, so I thought that I went by the book.
tcphoto is offline   Reply With Quote
Old 11-24-2013, 07:47 PM   #40
mitchell172
My Ride: 2003 E46 325i
Just was checking my car out and noticed my Whaler thermostat is leaking AGAIN from the same area. This is the second one I've put on in a year. Replaced the previous one due to the same leak. Pelican warrantied the part but I don't enjoy doing it and bleeding everything, etc. I don't have much faith putting a Whaler on again as you can understand - OEM supplier or not.
mitchell172 is offline   Reply With Quote
leak, thermostat, wahler
