Old 05-21-2013, 10:23 AM   #1
redarray
My Ride: 2002 E46 325i
Exclamation 02 E46 325i auto no cranking no start...
Hi everybody,
My 02 E46 does not cranking at all. Everything in the cluster instrument else seems ok. The car has a fresh new battery in it. When I try to crank it, there is no cranking, no click sound no voltage drop nothing happen at all.
I am just wondering is there a relay or fuse that I need to take a look?
I looked at fuse#14, which is a 5 amps fuse says Starter Interlock, it looks alright.
Thanks for any advise.
PROBLEM SOLVED. IT WAS A FAULTY KEY.
I get the other master key from my parent's house and the car started perfectly by using that key.
Thanks to everybody who helped in my thread, and hopefully it can help someone in the future.
redarray is offline   Reply With Quote
Old 05-21-2013, 10:25 AM   #2
My Ride: Lexus
probably starter
Old 05-21-2013, 10:49 AM   #3
redarray
Originally Posted by Mango View Post
probably starter
Thanks, but if it is the starter, shouldn't I hear a relay-like click sound? It is complete dead silent now...
Old 05-21-2013, 12:25 PM   #4
PhazedoutBmw
My Ride: Bmw X5, Bmw 325ci
+1 on the starter. Sometimes this will work..... Try tapping the starter and have someone start the car at the same time. If that works, your starter is going bad. I had the same problem. There wasn't any clicking noise...nothing when I tried to start the car. I did get it to start by tapping the starter just to get it to the shop.
PhazedoutBmw is offline   Reply With Quote
Old 05-21-2013, 01:00 PM   #5
redarray
Thanks, is there a easy way to tapping the starter? I couldn't even see it...
Old 05-21-2013, 01:38 PM   #6
E46@46
My Ride: 2003 325xiT
I'm with you redarray- at work and my car won't start. I need to try the same thing (tapping) later to get it home so I can replace the starter.
E46@46 is offline   Reply With Quote
Old 05-21-2013, 01:48 PM   #7
PhazedoutBmw
If you remove the cabin filter housing you should be able to reach it with something. Its right by the driver side fire wall. I removed mine and I was able to tap it with a pipe.
Old 05-21-2013, 02:01 PM   #8
PhazedoutBmw
I found these pics on the forums...hopefully it helps.. Good luck. Let us know the outcome.
Name:	starter location.jpg
ID:	506831   Click image for larger version
Old 05-21-2013, 02:02 PM   #9
briangl92
My Ride: VQ37VHR
You can also check voltage to the starter by taking the voltage across the + and ground nodes under the hood. I had an issue at one point between the battery and + terminal that caused a no start that mimicked a dead starter.
briangl92 is offline   Reply With Quote
Old 05-21-2013, 02:20 PM   #10
E46@46
What would be a good reading. I've read 12.3V or higher. ??
Old 05-21-2013, 03:23 PM   #11
briangl92
My Ride: VQ37VHR
That's about right. I think 11.5-13.5 is fairly normal.
Old 05-21-2013, 03:28 PM   #12
Leezy321
My Ride: 2001 bmw 325i
Just use a test light. Looks like a screw driver with a point and a light inside the handle. Connect one end to a ground or negative battery terminal. Then touch the positive wire going to the starter. Obviously you need 2 people when doing this. One person turns the key, the other checks to see if there's power getting to the starter. If there is, the starter is bad. If there's no power reaching the starter the next step is to check fuses/relays.
Leezy321 is offline   Reply With Quote
Old 05-21-2013, 03:52 PM   #13
ca5ua1ty
My Ride: 2001 330CI
Is it the correct battery? You cannot use a standard battery to start our engines, as the starter requires a much higher amperage. 750CCA should be correct if I am not mistaken.
Also, If you hear a single click and not repetative clicking when attempting to start the car, thats a good indication of starter issue.
"In a world full of ordinary, you need to stand out with something a little extraordinary."
ca5ua1ty is offline   Reply With Quote
Old 05-23-2013, 09:40 AM   #14
redarray
the battery is correct, i couldn't hear any click...no sound at all...
Old 05-23-2013, 09:46 AM   #15
choxor
My Ride: JDM
Have you tried another key.
Old 05-27-2013, 09:10 AM   #16
redarray
PROBLEM SOLVED. IT WAS A FAULTY KEY. Thanks everyone.
Old 05-27-2013, 09:37 AM   #17
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Can you be more specific about your faulty key?
What did you just try another key and It worked?
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 05-27-2013, 10:15 AM   #18
engineear
My Ride: 2001325i
The manual says the keys have a battery inside that charge when inserted in ignition. If it can't start the car, how will it charge?
1st post...no longer a lurker.
engineear is offline   Reply With Quote
Old 05-27-2013, 10:38 AM   #19
redarray
Yes exactly...
I left the other key with my parents. I got the key from them during my weekend visit and tried it this morning. The car started perfectly...
Still couldn't believe how come the key can be broken and apparently it is a common issue... I have my condo access key fob which is about 10 years old... same idea, but that cheap dirty made in china plastic key fob still works...
Old 05-27-2013, 11:13 AM   #20
BMWCaptain
Battery in the key fob is for the remote only. Security system code does not require the battery in the con to work. They are 2 separate things.
BMWCaptainE46.com
no crank, no start
