Old 06-09-2013, 01:42 AM   #1
nikos07
My Ride: 2005 330ci Cabrio
Rearview Mirror Auto-Dim
My rearview mirror seems to have all of a sudden gotten stuck on the auto-dim tint setting but there is an oval of non-tint in the center of the mirror and it has been stuck like this for about a week. I do not know what caused this and I do not know how to fix this.....?
nikos07 is offline   Reply With Quote
Old 06-09-2013, 02:06 AM   #2
Alex323Ci
My Ride: M3 & 323Ci (sold)
there is a light sensor in the front and back of you auto dim mirror. you could check for something blocking one of the sensors. you can also test by shining a light on one or the other sensors and see if it adjusts.
but i think it's just broken. these do that inside. there is a recent thread on two places that can repair your mirror. or buy a used one in the sites Classifieds.
Old 06-09-2013, 02:11 AM   #3
Alex323Ci
oh btw when these break sometimes the fluid inside leaks out on interior. mostly in hot climates. it's caustic and ruins leather and plastic in some severe cases. not trying to scare you but give you a heads-up to keep an eye in it (no pun intended)
Old 06-09-2013, 04:12 AM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
http://forum.e46fanatics.com/showthr...ghlight=mirror
malfunction, mirror, rearview mirror
