Old 03-19-2017, 07:09 PM   #1
mmad10
My Ride: E46 M3
Sunroof Problem - Please Help
Looking for some help. My e46 M3 has a mind of its own. My sunroof opens by itself when it wants. I have already replaced both door actuators and the sunroof switch and eliminated the GM5. All door locks and windows work perfectly. I have no idea what is going on with this. Any info is greatly appreciated.
The most common occurrence is while driving the roof opens ever so slightly and I can hear it so I close it. This will happen several times then it will start to open all the way but in 2-3 inch intervals sliding open. I close it every time and it just does it again. It seems that if I open it all the way and wait a few then close it it stays shut longer. This is always while the key is on....it never opens while off....yet.
Today as I was pulling in the garage it started opening all the way and the switch would not close it at all...it seemed dead. I let it sit for 30 min and turned key on and it did close. Another weird thing is that when I was pulling in the garage with the sunroof problem the car started "missing" ever so slightly which I have never heard before. After I went back out after 30 min this was cleared up as well.
I have no idea what to do from here. Thanks for all input.
mmad10 is offline   Reply With Quote
Old 03-19-2017, 07:28 PM   #2
scottjoh
My Ride: '99 323i & '02 540i
I have no idea why that would happen, but, you can pull fuse 46 to disable the sunroof motor. Did you replace the sun roof control module and check for chaffed wires in the area of the sunroof control module and motor.
scottjoh is offline   Reply With Quote
Old 03-20-2017, 10:54 PM   #3
crawsc
My Ride: BMW330xi
I was having same problem with all windows opening EVERY time I got in the car including the sun roof. Not ideal in inclement weather also drained my battery. Could be general module or problem with door locking mechanism. I sat in my car followed advise of someone on this site, to put key in the ignition turn to on position WITHOUT starting the car, press door lock switch 3 times, press lock and unlock button on key fab then remove the key. This solved my problem the windows and sun roof no longer open when I open car door. Good luck hope this helps. 2004 BMW 330xi
crawsc is offline   Reply With Quote
Old 03-21-2017, 12:58 AM   #4
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
That's just a straight up haunting, man!
///Mmmmmm...
Old 03-21-2017, 08:58 AM   #5
crawsc
My Ride: BMW330xi
MMad 10. Wondered if you tried my advise above. My car today is fully charged, windows no longer open by themselves. My key fab and door locks have never worked properly, but pressing the interior door lock up and down 3 times with door closed key in on position but car not started then pressing key fab before removing key from ignition corrected the problem
Old 03-21-2017, 12:27 PM   #6
hitbyastick
My Ride: 2002 325i
Have you tried the sunroof reset procedure?
Erryboddy got a plan till they get punched in the mouf - Mike Tyson
hitbyastick is offline   Reply With Quote
Old 03-21-2017, 08:54 PM   #7
crawsc
My Ride: BMW330xi
My interior door lock button and key fab proved to be my problem with sunroof and windows suddenly opening automatically. The problem is now gone. DIdn't need to once I got my door locks to work
