Dim Headlights. Time to replace? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-14-2017, 03:35 PM   #1
eyeballbill
My Ride: 2003 BMW 325i
I've had my 2003 325i for a few weeks now, and have not driven it much at night, but when I took it out after dark recently I noticed the headlights were pretty dim. My newer cars, and even my scooter have brighter headlights. I'm thinking replacement bulbs are needed, or is it just as easy to replace the whole headlight assembly? The lenses are not super clear, but not glazed over as some 14 year old cars are. Suggestions welcomed!
eyeballbill is offline   Reply With Quote
Old 07-14-2017, 03:43 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
All headlights shift in color and output as they age.
This being said there are some specific problems these cars have with headlights.
1. On standard Halogen headlights, the lens gray with age, they can easily be replaced.
2. If the car has HID headlights, the plastic reflector bowls in one type of projector assembly burn and degrade and the light output sux. There are options to get this repaired or updated.
3. Headlight adjustment is also an issue. If the headlights are HID, then the auto leveling may be a problem and the headlights may be pointing way too low.
4. You also need to determine of you car still has the original headlight assemblies, with cars this old, there is no telling what has happened over the years and what parts may have been replaced or swapped out.
5. Even just the bulb replacement will increase the color temperature and output of the light.
Old 07-14-2017, 03:58 PM   #3
My Ride: Lexus
To know what you need, we gotta know what you have. Post some pics.
Old 07-14-2017, 08:52 PM   #4
mjez
My Ride: bmw
Try this. I did it to both my cars and the difference is unbelievable.
Sent from my Nexus 6 using Tapatalk
mjez is offline   Reply With Quote
Old 07-14-2017, 09:51 PM   #5
jfoj
Looking at the picture of the OP car in the New Member Section, it appears his car has Projector headlights and possibly HID?
Need a close up picture of the headlight assembly and a close up of the projector low beam to see if there is wording/lettering on the projector bezel.
Old 07-15-2017, 05:51 AM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
If the headlight lenses are worn out then get these:
http://www.khoalty.com/headlight-lens-replacement.html
For xenon bulbs get the CBI, they are at a GREAT price now
https://www.theretrofitsource.com/bu...66240-cbi.html
Old 07-16-2017, 07:51 PM   #7
eyeballbill
Here are pictures of the current setup.
Old 07-16-2017, 08:45 PM   #8
Dogthebountyhunter
My Ride: 02 325xi
Imo those lenses look fine no need for new ones. If halogen i personally like sylvania silverstar bulbs.
Dogthebountyhunter is offline   Reply With Quote
Old 07-16-2017, 08:59 PM   #9
jfoj
Your car has Projector low beam headlights. Likely they are HID. You need to get a VERY close up picture of the shroud around the projectors to see if there are any letters cast in the lip of the shroud. You also need to take a picture/inspect the rear of the headlight looking for a ballast.
You can also run a VIN Decoder to see what the original option on the car was.
Hopefully you do not have ZKW headlights - http://forum.e46fanatics.com/showthread.php?t=990507
But in any event if the car has HID headlights, you should see them dip and rise at night when you start the car, if they are HID the auto leveling may also be a problem.
You need to know 100% what headlights the car has before you can start to understand what all the possible problems are. You also need to make 100% sure the headlights are original and not aftermarket. You should see some letters and numbers cast in the outer edges of the lens as I recall.
Old 07-16-2017, 09:35 PM   #10
HOODY007
My Ride: '04 330ci
Those are xenons - no E46 sedan/touring got projector halogens.
HOODY007 is offline   Reply With Quote
Old 07-17-2017, 12:02 AM   #11
Kpriest
My Ride: 2005 325i
Those are Xenon headlamps. You can see the word "xenon" on the kidney grille side, on the perimeter of the low beam. Most likely AL and not ZKW, you can verify by checking the manufacturer markings on the top of the headlight above the lens.
Your lenses do not appear to be oxidized in a way that would cause dim headlights. A set of new bulbs would be my first move and most likely the cheapest fix.
https://www.fcpeuro.com/products/hid...lb-flosser-d2s
Kpriest is offline   Reply With Quote
Old 07-17-2017, 03:48 AM   #12
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
Those are HID's and regardless of the manufacture whether Chinese or OE Phillips bulbs they only last so long and then the color shift and begin to dim.
You likely need new HID lamps, and the difference will be night and day. Two years ago I noticed that my fog lamps were actually aiding in my night vision down the road. My HID's were so dim that I literally could not drive without my fogs on.
/// MODS
/// Auto => 6-Spd Manual Conversion | Apex EC-7 | Koni/Ground Control Coilovers | Vorshlag Camber Plates | BMW Performance LCA | Mishimoto Intake Boots | GruppeM rep CAI | Shark Injector | 5000k Xenarc CBI 66240 HID | BMW European MTechII | BMW Performance Shifter | ACS Mirrors and Rear Spoiler ///
Old 07-17-2017, 04:53 AM   #13
Solidjake
Zero. Leaks.
Solidjake's Avatar
The look like ZKW due to the logo on the inner part of the light in the second to last pic....... The only solution is the zkw repair kit from theretrofitsource
