Here's what I did. In the plastic cover on the roof right by the rear view mirror, I spliced into the Universal garage door opener (white 3 pin connector) since I would never bother to use it. Green/Blue is switched hot. Brown is ground. Connected those two wires to a 2.5mm DCV connector ($2.39 at any electronics store) but you could also use a mono audio female connector, and drilled a 1/4 inch hole in the front of the headliner right by the rear view mirror. This connection can only be seen from the front of the car, is very discrete and looks like it is part of the car. I then cut my power cord to length, soldered on a 2.5mm male connector (again, cheap at $2.99 at the electronics store). It plugs into my new power outlet with a touch of slack but no drooping wires and that's that. Thanks for all the advice. I weighed each carefully and picked the one that suited my needs best.
I was thinking the same thing, I'm sure he had no issue given the DIY. It's the same DIY I used, and had my v1 hardwired in ten minutes.
Related Threads
E46 Fanatics Forum
17.9M posts
592.5K members
Since 2001
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
