I have a 2004 330i zhp and when I drive it the dsc light goes on randomly. But when I turn it off n start it back up it'll be fine. Has anyone ever had this issue?
There is no problem.
The DSC is working as it should.
It flashes when it is correcting what could end up a dangerous situation.
To be more clear:
When you press the DSC button, you turn off DSC, but leave on Differential Braking.
When you press the DSC button for more than 5 seconds you turn both off.
With the DSC on, the light will not be illuminated in the cluster, but when you begin to lose traction at any corner, the DSC light will flash.
Well mine comes on when the weather is warm and I've been driving in stop and go traffic. After shutting off the engine for a while when weather cools down, the light doesn't come back on at all. Anyone have the same issues? Is some kind of heat from the braking that is causing it to come on?
Most of these problems seem to be with wheel speed sensors.
Related Threads
E46 Fanatics Forum
17.9M posts
592.5K members
Since 2001
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
