When I'm downshifting my car will occasionally stall out and when I'm accelerating and shifting there is a thud coming from the rear end. Any ideas what is causing these malfunctions? 328ci 2000
Im having the similar issue. Started yesterday after I changed the expansion tank. I have another thread open about it, but maybe your answer could help me a bit.
Guibo...aka 'flex disk coupling' or technically the 'universal joint.' The rubber ring on the front of the driveshaft.
CSB...center support bearing...halfway down on the driveshaft...not visible without remove exhaust and heat shield.
If you were to have searched for either of these terms, you'd have found a thousand references. I'm nice, so will call this your mulligan.
Related Threads
E46 Fanatics Forum
17.9M posts
592.5K members
Since 2001
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
