Hi,
so my obd2 reading every and anytime is around 44+ oC
I am wondering if the sensor is goosed.. would that be causing the car to loose low end power as it may be overing or under fueling tell engine the wrong info..?
I really should get it on the diagnostic machine although no light is showing on the dash
Any suggestions from experts.. I am loosing a lot of low end power.. the car wants to dip on rev and cut out
I am unsure about the vanos as it is not leaking or burning oil, however the oil light comes on (yellow) when starting the car and goes off after 5-10 seconds and has always done that.. I read thats a sensor that goes at the bottom of the oil pan.
Any advice would be perfect.. thanks guys! :excited:
