So, I was looking at the thread about 3M tape being used on the exterior trim and thought why not on the interior? Has anyone done this? I am sick of the wood trim and want something more modern. Is the vinyl pretty thick or is it paper thin? Would it hold up to a little wear and tear?
I know what most people do, but IMO a home done spray paint job does not look the best. I'm thinking the vinyl would not have the depth that I would like. If I did it though, I could use the tape to wrap the front and rear reflectors and save another 100 dollars...
Do a search for "scotchcal" and you will find plenty of threads with pictures. I have done my interior trim with it and it looks great. :thumbup:
I am planning on getting the silver to do my exterior trim as well.
Wow, Kilronan that looks awesome. Can you give me the exact model number you chose? Also do you think it is a close match to the exterior paint, enough to use it on the reflectors without being noticeable?
Thanks! The tape I used is from AveryGraphics. The picture below shows the back side of the sheet. I'm not sure to which an extent it will match the exterior paint of a silver metallic car. But it should be close.
Thanks! I agree, it looks so much better than I even expected. Probably the cheapest mod I've ever done to the car. But it makes such an impact on the appearance of the interior.
I just used water, but it's important to use a cloth which doesn't fluff. If dust particles get caught between the trim and the tape, it will show through.
ZMZIP, when you get the film you ordered can you let me know what you think of the color match to your Titanium Silber body color.
Also, I presume you had to buy 15"x30' size. You'll have lots left over after you've done your trim - maybe I can buy some from you if you think the body color match is good.
Did you consider the 7725-120 over the 180C-120?
3M 180C can also be had in a metallic light silver.
From what I read, the #120 Satin Aluminum is a very close match to the titanium silver paint. I bought a roll that I will be using on the trim and possibly on the front and rear reflectors. I will post up pictures once I get it all done.
I will post up pictures and maybe a quick DIY guide. The vinyl still hasnt been shipped out yet though . I checked out the armrests and they will be kind of tough. I assume the wood trim on top is glued to the plastic base. The only way to cover it will be to tuck the edge of vinyl into the crevice between the trim and plastic base. Sounds like it will be tough to make it look right...
I just found a local supply shop for the 7725-120. Cost for 24" wide is $2.69/foot. To do the body side moulding I'm guessing I'll need no more than 5 feet (I'll be measuring to be sure). I'll be leaving my interior trim alone, as it's already 'carbon fiber' (ZHP). I'll pick it up 7725-120 today or tomorrrow if I like the color match, then apply it to the moulding this weekend.
I hope you get your order soon and good luck on your install.
Very nice, post up some pics and tell us how it matches up when you get a chance.
Related Threads
E46 Fanatics Forum
17.9M posts
592.5K members
Since 2001
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
