E46 Xi Forum
Old 01-02-2017, 01:44 AM   #1
belouder
My Ride: 2005 325xiT
Clunking sound in front-please diagnose
2005 325 xiT with 120K:
Several weeks ago I started hearing (and feeling) a clunking sound coming from somewhere up front-possibly on the left hand side-feels or sounds low down. It happens when going over road bumps (pavement cracks, manhole covers) but not regularly and occasionally clunks when just driving along-usually only at lower speeds 15-30 mph. I don't hear or feel it while driving freeway speeds. A stop at our local indie BMW repair shop told me front lower arm ball joints were failing along with the bushings. I ordered parts and just finished replacing control arms, ball joints and bushings. When I removed old arms-although I tore up the ball joint boots getting them to release-the ball joints felt solid and tight. But all the new parts are in.
Unfortunately, the sound (and feeling) continue with no change. When the car is parked, I can't create the sound when bouncing the car suspension or puling and twisting wheels. Years ago I had a car with front strut suspension and remember a similar sound when one of the struts had failed.
Does anyone have any recommendations on where I can look on the car and/or methods to create road simulation to diagnose what the problem could be?
Some more notes: Steering seems to feel solid and responsive-no slop or sounds related to steering. The sound doesn't happen when accelerating or stopping (engine mounts or brake components?) and doesn't appear to happen when driving above 40 mph (maybe I just cant hear it). Nothing in the engine compartment is obviously loose and flopping about. 6 months ago one of the idler pulleys on the serpentine belt failed and a shop replaced it and the fan pulley along with the belt. Not sure if this issue could be related to that repair-it happens when going over road bumps and not related to engine speed.
Also, a friend drove the car for several weeks and I believe caught the front valence on a parking curb and flexed it quite a bit. I've just discovered the front right inside wheel well cover (protects the headlight cluster) is missing-it could possibly have been dislodged when the valance was tweaked. Not sure if this damage could be a contributor to the noise (loose body part or bumper?) but pushing and pulling on panels and bumper reveal nothing loose.
Thoughts?
Thanks,
Bri
belouder is offline   Reply With Quote
Old 01-02-2017, 07:40 AM   #2
GROUNDSKEEPERWILLY
My Ride: LR Disco2
I had an almost identical sound coming from my wife's Subaru Forester. Turned out to be the front sway bar end links and sway bar bushings.
Might start there. If not, you still might look at the strut. You can't always simulate road bumps just by bouncing the front end up and down while parked.
GROUNDSKEEPERWILLY is offline   Reply With Quote
Old 01-04-2017, 09:40 PM   #3
Dustman999
My Ride: 2002 325xi
Check your tie rods. Are they rusted or anything? My car does the same thing in the front right tire, and I am assuming it is the tie rods because mine are quite rusted and need to be replaced (can't even align the wheels because of the rust).
Good luck!
Dustman999 is offline   Reply With Quote
Old 01-07-2017, 04:42 AM   #4
Dreamliner330
My Ride: 330xi
My car has a bit of that low level sounding clunk when hitting bumps. My CV boots are torn and click when turning. I'm trying to figure out what to check to replace while I'm in there for that.
Dreamliner330 is offline   Reply With Quote
Old 01-08-2017, 12:30 PM   #5
WilloCO
My Ride: '05 330xi 6 speed
On mine it was ball joints. Jack it up and take off the front wheels. Once mine were off it was trivial to find the issue.
WilloCO is online now   Reply With Quote
Old 01-09-2017, 12:24 PM   #6
belouder
More notes: I've replaced both axle within 15K miles. Regarding ball joints-do you mean those associated with lower control arms? If so-I've replaced both arms, bushings and all four ball joints.
I'm going to get the front end off the ground tonight and see if sway bar bushings or links are gone.
Question: I've heard that around 120K miles just about all suspension parts will need to be replaced. Is this generally the case?
And thanks for the input!!
Bri
Old 01-10-2017, 05:17 PM   #7
Mariner05
My Ride: 2005 325xi
You already said you were checking the swaybar links and bushings - that's good. Did you replace struts ? Those are one of the "it depends" things. Some get 160 K miles on a set and some get 50K. If the noise is only on sharp impact and not at highway speeds AND you have checked all else, then suspect struts. You will not be able to assess them by a bounce test.
Good luck on trouble shooting.
Mariner05
Mariner05 is offline   Reply With Quote
Old 01-11-2017, 03:21 PM   #8
dutchhome
My Ride: 2004 330xi
For what it's worth I had a similar problem in my rear suspension. It turned out my rear spring had partially broken and I heard the broken off piece moving around when I would hit a speed bump. :-)
Sadly I still haven't replaced it.
Sent from my Nexus 5X using E46Fanatics mobile app
dutchhome is offline   Reply With Quote
Old 01-13-2017, 03:07 PM   #9
squirrelhill
My Ride: 330cic, 325xit, e34
+1 I had a similar clunk and it was the front sway bar end links. Remember to torque them down while the car is loaded.
squirrelhill is offline   Reply With Quote
Old 01-27-2017, 12:47 PM   #10
belouder
For those that have followed this and offered solutions-I was finally able to get time with the car to poke around and see if I can find the issue. Turned out that one of the swat bar end links was lose (barely!!) at the strut housing connection. I had removed these earlier when I replaced the font axles and must not have tightened them enough. Not an easy torx/locknut combo to get properly tightened. I was able to finalgle a tool setup that allowed a good tightening and magically the clunking went away.
I was a bit surprised how much such a small play could translate into such a large sound and feeling. A visual inspection of the rest of the suspension rubber bits (sway bar bushings, link ball joints) found everything else to be solid.
Thanks to all for the input. It really helped in trying to focus on possible areas.
But with 120K+ miles, I'll still need to gather replacement parts for things that will wear out.
BK
