Just finished up a 2J swap into a M3 with a Promod 94mm turbo. The car is running on E85-E98. It should be good for about 1700 RWHP but we ran out of fuel at 1405 RWHP.
http://www.youtube.com/watch?v=srTo5dIGNto
http://www.youtube.com/watch?v=ojdaMSSkmes
If you look at the dyno, you can see where the tires let go. I revved it to 9500 but because our dyno calculates RPM by wheel speed, once the tires let go, the rpms stop climbing. If you extrapolate the curve across it would have made close to 1500 if the tires held. The ProEFI calculated 1700 crank HP !!
