Old 02-13-2014, 06:09 PM   #1
djdirec
My Ride: has roof rails
DME tuning for ZHP swap
I am installing a 2005 ZHP motor in my 2002 325 wagon this weekend. Who should I use to tune my DME? any recommendations from experience or is there someone local in San Diego that can do this?
Touring the bimmer
djdirec is offline   Reply With Quote
Old 02-13-2014, 08:55 PM   #2
HakenTT
My Ride: 323i with S54
True ZHP swap will be using MS45.1 engine management.
HakenTT is offline   Reply With Quote
Old 02-13-2014, 10:11 PM   #3
djdirec
I have the ECU and wiring harness, what else do I need?
Touring the bimmer
Old 02-14-2014, 11:20 PM   #4
elgreengo
My Ride: e46 touring, e36m3
I am also contemplating this swap in my 2000 wagon, with lame ms42 DME..
Spoke to RPM Motorsports in Canada/Cali, and they can flash out the EWS, so the ms45 DME can be run, with the Zhp's throttle pedal being required. Quoted ~600. Still looking at options.
elgreengo is offline   Reply With Quote
Old 02-15-2014, 01:15 PM   #5
HakenTT
Won't work, you will still be required to wire up the EKP fuel pump module. I sell a tune where you don't have to have EKP module, the MS45.1 will run the existing regular fuel pump relay
my price is $800
fuel pump module unit. ews box, key,
Old 02-16-2014, 12:12 AM   #6
djdirec
Thanks for the info, now I am on the right track!
Touring the bimmer
Old 02-16-2014, 11:14 PM   #7
elgreengo
Haken, can you delete the EWS?
Changing the key is a pain, if you go to the dealer for a replacement, they ask for VIN# and proof on ownership.. Issue if you are using a junkyard EWS.
Old 02-17-2014, 01:27 AM   #8
HakenTT
yes but I am not cheap
dme, engine, swap, tune, zhp
