Please help! No start issue - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-02-2015, 08:48 PM   #1
jsm2186
My Ride: 325xi
Hi,
I have 2003 BMW 325xi base model stick shift.
I have a weird issue, and I need help.
On sunday, my car was not starting normally (slow to crank). After starting I tested it, and the alternator was working and charging the battery.
I tried starting again, and it wouldnt crank so I put the battery charger on, and tried a little while later and it started right up.
After sitting overnight it started, but cranked very slowly. As this was the same issue I saw a few years ago, I knew it was the battery.
I took the battery out to sears to get it "checked" and a get a new one.
Battery was out of the car about 4 hours, and I put a new one in. Everything worked well, lights, radio, etc., but as soon as I went to start it, it wouldn't crank at all. No click, nothing....like it wasn't even giving power to the starter at all.
I have read about possible issues causing this issue....but nothing is leading anywhere.
I tried reprogramming keys, and no luck. I asked the dealer to reset EWS, and they said no luck. They don't know what's causing the issue for certain.
Can anyone please offer some help? Has anyone experienced this?
If you need additional information please ask. I appreciate your help.
I don't believe it to be the starter because of the circumstances outlined above. It wouldn't make sense to me.
jsm2186 is offline   Reply With Quote
Old 09-02-2015, 09:12 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Hate to break it to you, 2003-2004 xi starters give out with little to no warning.
They are also a MAJOR PITA to replace.
Suggest you pull the intake and replace the starter from under the hood.
Shops want like 4 hours to replace the starter.
DO NOT replace it with a cheap rebuild, if you can get a new one, spend the money.
One thing on an XI is you only want to replace the starter ONCE.
Old 09-02-2015, 09:13 PM   #3
OCD+
My Ride: BMW 3er
If you changed the battery, I would check the fuel pump. It's a common failure in old high mileage cars. Read this thread http://forum.e46fanatics.com/showthread.php?t=929501
Originally Posted by cole3636 View Post
If you get a 325i up to 400hp you should buy a ****ing lottery ticket
OCD+ is offline   Reply With Quote
Old 09-02-2015, 09:24 PM   #4
jfoj
This is NOT a fuel pump problem.
Old 09-02-2015, 09:24 PM   #5
cvx5832
My Ride: 325Ci, 325Cic, C300
Hi,
I think it IS the starter because of those circumstances. I have a YouTube clip of a bad starter and it sounds like a weak battery. When I get behind a computer I'll post the video.
cvx5832 is offline   Reply With Quote
Old 09-03-2015, 12:34 AM   #6
OCD+
My Ride: BMW 3er
You have much more experience and I always trust your advice. Whenever a car doesn't start I usually check for two things spark, and fuel,and since he changed the battery that's why I suggested your fuel pump thread. I was just trying to help, I missed the starter therefore I apologize about the confusion.
Old 09-03-2015, 03:27 AM   #7
jfoj
No problem, just want to make sure the OP or others did not get mis-directed.
dme, ews, no start, starter, won't crank
